Author Topic: How to hookup shaker motor with PAC drive?  (Read 3010 times)
rob1234
  • Last login:September 23, 2022, 07:40:58 am
« on: May 15, 2017, 09:05:39 am »
I am trying to wire a sega after burner shaker motor to a PAC drive. This should be the same/similar to the outrun shaker motor. Does anyone know how to wire this? Do i need to use the SSR board that is currently used in the cabinet? The yellow and black wires connect to the game pcb. The red and blue outside wires seem to be the power source.
« Last Edit: May 15, 2017, 10:46:39 am by rob1234 »
rob1234
Re: How to hookup shaker motor with PAC drive
« Reply #1 on: May 15, 2017, 09:07:45 am »
Pic
SailorSat
  • Last login:February 18, 2026, 07:07:40 pm
    • For Amusement Only e.V.
Re: How to hookup shaker motor with PAC drive?
« Reply #2 on: May 17, 2017, 02:33:31 am »
Hm... The two lines coming from the game board would be GND and the "shake it baby"-signal itself.
It should be enough to hook up the PAC drive there.
rob1234
« Reply #3 on: May 17, 2017, 10:00:12 am »
Do I need to run power from a pc power supply to the other end of the board? Or does it really need power if the PAC drive is feeding power in from the pcb end?
« Reply #4 on: May 17, 2017, 01:08:37 pm »
Ok the lines coming from the pcb are most likely logic lines... they won't be over 5v which isn't nearly enough to power a rumble motor.  The board you have pictured is most likely an amp board, which would require the original game's power supply and you drive the logic pins on the board with the pac drive.
Get out a multi-meter and be sure..... if you have 12-30v flowing through your pac drive you are going to fry it and most likely your pc's usb port as well.
