Author Topic: Another Cocktail Arcade Build  (Read 6958 times)
GrizzlyThunder
  • Last login:January 15, 2026, 09:02:03 pm
« on: May 11, 2017, 02:46:16 pm »
Hey All,
so this is my first arcade build its nothing fancy very basic. i am making this cocktail as a gift for my brother, although its not done yet it sure has been fun to mess and play with.
here is the img post http://imgur.com/a/U2Z6v
please feel free to add any criticism, complements, or questions.
  • Last login:Today at 08:50:58 am
Re: Another Cocktail Arcade Build
« Reply #1 on: May 11, 2017, 03:03:33 pm »
Small criticism... looks like that plywood didn't take stain well.  Some stain conditioner first might have helped you out there.
Other than that, nice work, good solid craftsmanship.   :cheers:
GrizzlyThunder
« Reply #2 on: May 11, 2017, 03:14:22 pm »
As I'm still new to this craft and beginning wood working, could you expand upon what you mean by "didn't take well" and what the conditioner would do? Thanks
« Reply #3 on: May 11, 2017, 03:19:09 pm »
So the stain looks uneven in places.  There are some darker splotches, and very light places as well (like some of the grain).
Conditioner will get down into the grain and just helps the stain looks more even & uniform.
Not all wood needs conditioner.  I usually test a scrap piece before staining to see if needs conditioner or not.
GrizzlyThunder
« Reply #4 on: May 11, 2017, 03:24:43 pm »
Gotchya, yeah a few places took more than others. The front of the control panels I had to remove most of the grain panel don't look terrific either. The lighting of my workshop does not help at all either. Thank you for observation, I'll keep that in mind when I'm doing my upright.
« Reply #5 on: May 11, 2017, 03:25:37 pm »
Found an example online:
GrizzlyThunder
« Reply #6 on: May 11, 2017, 03:31:55 pm »
Wow that's great! I'll be sure to look for conditioner next time.
Quick question I forgot to add to the title. Since I used a router to bevel the screen area should I paint it black of leave it stained?
« Reply #7 on: May 11, 2017, 03:33:51 pm »
I'd paint it black.    :cheers:
ChurchOfSolipsism
  • Last login:May 09, 2023, 01:43:39 pm
« Reply #8 on: May 11, 2017, 05:25:46 pm »
Man, stained wood looks just so classy IMHO. This is going to be a really fancy cab when it's finished.
Unstupid
« Reply #9 on: May 30, 2017, 05:00:58 pm »
My only criticism, besides the stain which Haruman already covered, is the cup holder.....  WTH do you need a cup holder for.  This is a cocktail table.  You put your drinks ON a table, hence cocktail table.  You'll have enough bezel area to put a drink on the table and still be able to see the screen.  Rule #2: Don't make things more complicated than they need to be.   ;)
GrizzlyThunder
« Reply #10 on: May 31, 2017, 07:12:57 pm »
You are absolutely right, I changed the design later without the cup holder since it was silly. I always get too excited and forget the KISS principle.
WeChat: GrizzlyThunder
« Reply #11 on: May 31, 2017, 09:27:00 pm »
I'm skeptical that two people will ever want to play a two player horizontal game like that.  With a PC you can run two rotated images at the same time that'll work with the vertical controls.
Wood burn a five pointed star and write "come and take it-Cade" on the side and I'd buy it.
GrizzlyThunder
« Reply #12 on: June 16, 2017, 11:47:28 am »
The horizontal two player is quite comfortable. I'm 6' + and there's plenty of room. Plus this is primarily going to be played and used by children with the occasional adult.
I was thinking more along the line like biggusdickus on the side with a come and pull it beneath.
GrizzlyThunder
« Reply #13 on: June 16, 2017, 11:49:11 am »
This is the first coat of black paint for the bezel. Improvement?
I was pondering painting the edges black too since I'm not t-molding it.
« Reply #14 on: June 27, 2017, 02:32:35 pm »
Black looks better on the bezel for sure
menace
« Reply #15 on: June 28, 2017, 09:10:27 pm »
How are your control panels fastened to the side--wood screws and glue or something else?  Just curious as I have been waffling on a two player cocktail with side by side (on the side) controls.
GrizzlyThunder
« Reply #16 on: July 05, 2017, 05:45:20 pm »
It is by biscuit. Using a plate joiner measuring two areas then cutting a small chunk out of there to stick this biscuit with some glue. Makes a very strong joint. And! This would the perfect reason to add the tool to the arsenal.
GrizzlyThunder
« Reply #17 on: July 05, 2017, 05:46:26 pm »
What's your thoughts on painting the rest of the edges where t-molding traditionally would be?
yamatetsu
  • Last login:Today at 07:56:20 am
  • Just because.
« Reply #18 on: July 05, 2017, 06:19:49 pm »
I have painted the edges of my first cab. Lots of masking off to do, and in the end it looks like ... paint. I used edge-banding on my second cab, ironed it on and, since it was wider than the cab's edge,  cut off the excess with a knife. This looks way better than paint, but it takes a little bit of practice to cut the excess off without damaging the wood.
