Author Topic: X-Arcade Solo Dimensions Request  (Read 2047 times)
Baezl
  • Last login:August 24, 2024, 07:11:26 am
« on: May 11, 2017, 11:27:36 am »
This is probably a long shot but I am looking for the dimensions of the X-Arcade Solo base.  I am looking for the following if anyone with one of these can help:
1 - Side boards (Length, height at the front and height at the back - to determine angle)
2 - Front board (Height X Length)
3 - Rear board (Height X Length)
I have just the top portion with no base and want to get the base as close as possible to include the tilt.
It is highly appreciated.  Thank you.
Luis
nexusmtz
Re: X-Arcade Solo Dimensions Request
« Reply #1 on: May 28, 2017, 10:48:47 pm »
The 3/16" thick base boards are beveled at 45 degrees to fit together, so all pieces cover the length or width. (more likely, a single board was cut, routed at the three corner/fold points, and folded into a rectangle.)
The base is a rectangle 13 3/4" x 7 1/2"
The front of the base is 2"
The back of the base is 3 1/4"
