Author Topic: ON Off Shim for pi  (Read 5541 times)
ugleymatt
  • Last login:October 11, 2022, 12:13:37 pm
ON Off Shim for pi
« on: May 06, 2017, 02:24:39 pm »
This looks like it might be a nice way to turn on and off a pi using a switch
https://shop.pimoroni.com/products/onoff-shim
mahuti
Re: ON Off Shim for pi
« Reply #1 on: May 06, 2017, 10:28:10 pm »
Cool. 6£ is a lot better than most of those other options.
Titchgamer
« Reply #2 on: May 07, 2017, 04:06:22 am »
Indeed nice price.
Shame it needs to be soldered to the GP10s though, PnP would be better
ugleymatt
« Reply #3 on: May 07, 2017, 04:13:05 am »
I'm going to order one as soon as they are back in stock and give it a try
mahuti
« Reply #4 on: May 07, 2017, 11:55:47 am »
Yeah. The soldering sucks. At least it's pass through
Titchgamer
« Reply #5 on: May 07, 2017, 01:17:43 pm »
Let us know what they are like Matt as £6 is a excellent price.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #6 on: May 07, 2017, 02:15:31 pm »
Indeed nice price.
I'm guessing that was done because many people won't want to mount it above the GPIO pins. From the description, it only appears to use a single pin. So it's a bit of a waste to use up another 11 pins just for mounting purposes.
Anyway, it's a nice idea, and long overdue. I can't understand why the RPi designers have never included on on/off switch.
Titchgamer
« Reply #7 on: May 07, 2017, 02:18:40 pm »
Indeed nice price.
Nor me tbh.
Its one thing that pretty much every pi project needs!
ugleymatt
« Reply #8 on: May 08, 2017, 05:40:51 am »
Its back in stock and I've just ordered one.
Might need to buy a new soldering iron as my old one is pretty rubbish.
« Reply #9 on: May 08, 2017, 04:12:18 pm »
I ordered a couple to try out. I'll post my results when I've finished installing.
But yeah, why this wasn't built into the Pi is beyond me.
markc74
  • Last login:November 27, 2025, 06:32:39 pm
  • Flipping out
« Reply #10 on: May 08, 2017, 04:45:42 pm »
If you're after an easy build option for a pi then the picade is pretty handy. Has the powe switch, joystick controls and an amp built in for £15.
https://shop.pimoroni.com/products/picade-hat
Picked one up a while ago - just need some time to get my head around the os and install attract mode.
  • Last login:Today at 01:47:01 am
« Reply #11 on: May 08, 2017, 04:57:27 pm »
Sure would be nice if some of you would stop hitting F5 on that website and let someone else take a look at it.
chito
  • Last login:July 23, 2023, 12:29:26 pm
    • forum.arcadecontrols.com/index.php/topic,151843.0.html
« Reply #12 on: May 10, 2017, 08:27:10 am »
eta prime has a solution for retropie thar only requires a momentary switch. theres even a solution that uses the audio jack to free up the gpio pins
audio jack
