Author Topic: No text modes on Linux AdvanceMAME  (Read 1159 times)
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« on: January 27, 2004, 12:39:30 am »
I have a TNT2 in my Linux-based MAME PC.  It's connected to my arcade monitor (standard res only) by a JPAC.
When I'm trying to set up AdvanceMAME, running advcfg or advv gives me an error stating "No text modes are available for your device.".
What do I do to get around this?  Is there a better piece of software that I should be using for this configuration?
AMIGrAve
  • Last login:June 11, 2024, 03:56:35 pm
Re:No text modes on Linux AdvanceMAME
« Reply #1 on: January 27, 2004, 04:03:10 am »
Perhaps this can help a bit:
In the sources of advancedmame, according to v/draw.c :
No text modes available for your hardware.
Please check your `device_video_p/h/vclock' options in the configuration file.
Eventually add a specific modeline named '" DEFAULT_TEXT_MODE "' and ensure
that you have a text mode video driver compiled in.
Ensure also to use the auto option for device_video.
Do you use X or svgalib ?
Did you compile yourself or are you using the binaries from advancemame website ?
