February 04, 2026, 01:58:48 pm
Can you post the contents of your config.txt file? Seems like there must be something off in the settings. Do you have anything connected to the GPIO pins?
sudo pico /boot/config.txt
Just for reference: https://www.raspberrypi.org/documentation/configuration/config-txt/https://www.raspberrypi.org/documentation/configuration/config-txt/video.mdconfig.txt is kind of like the BIOS. If you are in the console or logged in via SSH you can open (and edit so be careful) using this: Code: [Select]sudo pico /boot/config.txtIf you're editing the SD card directly, then it's in the boot partition.If you haven't ever edited that file, then it's probably something else if you're just using the standard VGA output. The only time I've had issues with screens not showing is when the config.txt is configured wrong, or the monitor is turned on after the Pi starts up... and I haven't configured the config.txt
