Author Topic: Arcade crt chassis/pcb board - heat?  (Read 2311 times)
jtb1987
  • Last login:August 15, 2021, 01:08:10 am
« on: April 29, 2017, 11:50:48 pm »
Hi guys,
So I've finally gotten my mame cabinet working with a Arcade CRT with groovymame and crt emu drivers and a JPAC.
I've noticed the pcb/chassis board behind the crt feels kind of hot to the touch when everything is working. Is this the expected behavior? Or a sign that something is about to go?
I've attached a pic of the specific sections that seem to be hot. Thanks for any help!
Sent from my SM-G920V using Tapatalk
  • Last login:Today at 08:44:50 am
Re: Arcade crt chassis/pcb board - heat?
« Reply #1 on: April 30, 2017, 12:08:10 am »
Yes. Your health. You might not want to be poking around a live CRT with your hands unless you really know what you are doing.
jtb1987
« Reply #2 on: April 30, 2017, 02:17:15 pm »
Very good advice, thank you! I'm going to follow it.
Regarding the heat coming out of it, is this indicative of a component failing somewhere? Or is it normal for those two sections to get hot?
mourix
  • Last login:December 02, 2025, 08:28:56 pm
« Reply #3 on: April 30, 2017, 04:49:23 pm »
What you're pointing at are in fact heatsinks with the purpose to cool down hot parts. Unless they run blistering hot, all should be fine.
If heat is a real problem, you will notice from a distance.... so looky but no touchy :censored:
Ken Layton
  • Guru
  • Technician
« Reply #4 on: April 30, 2017, 11:20:32 pm »
Those are heat sinks. They dissipate the heat from parts that normally run hot.
