Author Topic: No Blue color on arcade monitor?  (Read 3964 times)
crapjoint
  • Last login:November 07, 2007, 08:14:20 pm
« on: January 26, 2004, 08:42:44 pm »
My 27" arcade monitor has no blue color.  When I do the test on the machine it shows red and green and fine, but blue is just a black screen.  Below is the monitor info, can anyone help, and also tell me about my monitor?
Zenith
100-00809-09
A68AGDD1X
D4RC0156-008
EIA101
Ken Layton
  • Guru
  • Technician
Re:No Blue color on arcade monitor?
« Reply #1 on: January 27, 2004, 12:26:45 am »
That's the number of the picture tube not the manufacturer or model of monitor. Zenith made some pretty bad picture tubes and it sounds like the blue 'gun' in your tube is either shot completely or very weak. Connecting it to a restorer/analyzer unit will tell you if the tube is shot or can be salvaged.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 27, 2004, 10:38:43 am »
It's also possible that your blue driver transistor on the neckboard is bad.
crapjoint
« Reply #3 on: January 27, 2004, 06:58:58 pm »
Ok, is this an easy fix, and where on the tube can I find the model number?
crapjoint
« Reply #4 on: January 27, 2004, 07:52:07 pm »
I tried to find the part number on the tube, and the only thing I can find is it says on the chassis, replace only with K7500.  Does this mean it is a WG?  Does this help me?  It does have a Zenith sticker on it, but from what I've read, they made these for WG?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: January 28, 2004, 01:33:48 am »
Wells-Gardner places the monitor model number sticker on the metal framework of the monitor---never on the picture tube. Wells-Gardner's model numbers usually go something like 25K7191 as an example.
crapjoint
« Reply #6 on: January 28, 2004, 01:54:00 am »
I believe it is the K7500 as I found the spec sheet on Wells Gardner website and the chassis pictures and everything are the same so it must be the K7500.
http://www.wellsgardner.com/wellsgardner31/supportdata/K7500.pdf
Do you know a good way to use this with Mame?  And to fix it?  Thanks for your help.
