Author Topic: Well it used to be a SEGA Super Megalo 2....  (Read 4998 times)
syntax_x
  • Last login:October 27, 2019, 09:32:44 pm
« on: April 26, 2017, 09:30:01 pm »
So ive been chipping away at this little project for a few years now and I think its almost done.
All work besides painting has been done by me.
Gutted a Sega Super Megalo 2 and made it shorter so it can fit through a door and function in a living room.
Was a fair bit of welding and fiberglass work but came up sweet.
In my opinion its one of if not the best machines to play on.
Its big and heavy but there's plenty of room between both players, everything is exactly the same so its always a fair fight,
Sanwa JLF joysticks with QanBa round gates, heavy springs, short stick and alloy bat-top. Ends up the same height as a stock JLF ball-top but that nice batty feel
HBFS30 buttons all around, easily one of the best buttons ever made, no idea why they went under but I'm glad I stocked up when I did.
The smaller buttons are IP67 rated buttons, they'll last forever, nice firm feel. The missile switches are covering I-Pac controls for EXIT RESET SAVE LOAD
When each emulator loads in Launchbox I run an autohotkey string that on-the-fly programs the I-Pac to suit the emulators mappings. Having this centre control panel across emulators is awesome.
The control panel when running emulators is hooked up to a hacked up PS2 controller that I've added HDMI breakouts to to make changing from console to emulator easier.
The hacked ps2 controller plugs into a Blissbox 4-play unit. Same goes for both players.
If I want to use a different controller I have to open the control panel, unplug the hacked ps2 controller from the Blissbox and then plug in whatever controller I wish.
I tried using a HDMI switch to make this simpler but to no avail.
Players 3 and 4 can just plug straight into their HDMI ports, hit the ports reset if needed and play.
The 4play is basically 4 "Virtual" controllers in a hardware form.
You map the four controllers to all your emulators, then when you want to change controllers per game Blissbox does all the hardware mapping and compatibility for you.
It supports force feedback also, and even pauses most emulators when changing controllers.
To be able to play streetfighter on MAME one minute, then have friends walk through the door and plug in 4 Gamecube controllers and switch to Mario Kart 64 with proper feedback and analogue inputs is bliss.
When running on consoles the control panels HDMI lead is plugged into a ps360+ or Brooks adapter.
I guess what I've made here is pretty much one big 2/4 player controller that can use ANY console controller (pre Xbox) and also be used on ANY console to date.
It could also take down a tank.
http://forum.arcadeotaku.com/viewtopic.php?f=6&t=5250
  • Last login:Yesterday at 11:01:06 pm
Re: Well it used to be a SEGA Super Megalo 2....
« Reply #1 on: April 27, 2017, 12:01:10 am »
The answer is none more black.
syntax_x
« Reply #2 on: April 27, 2017, 12:22:01 am »
:p It's just a base color.
 I plan to cover it with vinyl decals
Richie_jones
« Reply #3 on: April 27, 2017, 01:14:27 am »
Nice. Can you post some vids of it running..
syntax_x
« Reply #4 on: April 27, 2017, 03:30:41 am »
Sure, I'm just finishing up some autohotkey scripts to clean the ipac on exit. When someone pops over tonight ill get some video.
Any requests? I was thinking of navigating to street fighter ps1 on the arcade cp then changing to a ps2 controller, then using that controller to navigate out into a N64 game, and switch controls to gamecube.
Should be a decent representation of functionality.
Titchgamer
« Reply #5 on: April 27, 2017, 03:49:54 am »
Looks lovely!
Very unique cant wait to see videos!
  • Last login:Yesterday at 01:01:21 pm
« Reply #6 on: April 27, 2017, 04:24:39 am »
I wouldn't go too crazy with the vinyl. It looks really good as is. I would like to see this cab in action. Bring on the videos!
stigzler
    • Mago Arcade
« Reply #7 on: April 27, 2017, 04:40:20 am »
Looks fab. Lovely finish.
Lesve as is. Dont ruin with decals.
syntax_x
« Reply #8 on: April 27, 2017, 07:06:41 am »
Quick video showing the system in action, super dodgy quality.
I'm not sure how to embed videos on this forum yet sorry.
Also warning for headphone users I dropped my phone halfway thru :S
« Last Edit: April 27, 2017, 02:09:00 pm by syntax_x »
NIVO
« Reply #9 on: April 27, 2017, 02:52:31 pm »
ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh my frickin earses!
« Reply #10 on: April 27, 2017, 04:00:01 pm »
Rotate your damn phone, peasant.
stigzler
    • Mago Arcade
« Reply #11 on: April 27, 2017, 05:39:13 pm »
