Author Topic: Makvision M2929D1G-62 displays on machine a but not machine b of similar build  (Read 2377 times)
Acpowell
  • Last login:April 05, 2019, 11:18:00 am
All, I have a 2929d monitor connected to a Windows 10 machine that is almost identical to the machine this monitor was shown working on. Only difference is the video card.
When I connect an just a lcd via HDMI everything works but as soon as I connect the crt I loose video on both. I have also tired using crate up driver. I made that work with my neotec 2720 (has a bad tube though).
I have also tried just using the Intel onboard gpu. No display either. It does show the disconnected message.
Any thoughts? Side note: I believe my friends machine this came from has a arcade Vga from ultimarc.
Acpowell
This weekend using team viewer I remoted in while it was only connected to the CRT and made sure all the settings were correct for video and it made no difference.  I also verified all the connections from the end of the VGA cable to the neck board were good.  I have friend that has a newer version of this monitor and his tells him when the signal is wrong.  Mine seems to not even know there is a signal present and the whole thing where is disconnects all monitors when you plug in the VGA is weirder.  his doesn't do that either.
Any help would be appreciated, I am pulling my hair out trying to figure this out.  It is literally the only thing left to do on my build.
Acpowell
I believe I kind of have a resolution for this.  It ends up that even-though I thought I had CRT-EMU configured correctly I didn't.  I was able to make this work using the built in intel card buy setting it ti 800x600 and 60hz refresh.  If I make the CRT-EMU work on my amd card I will update.
