Author Topic: I Know MAMEWah is Essentially Dead.....  (Read 2168 times)
DrLarryE
  • Last login:January 23, 2018, 10:03:26 pm
« on: April 19, 2017, 06:25:40 am »
....but I still like it. I have an issue that I hope somebody might be able to help with.  I finally updated MAME (0.134 to 0.184). Since my original HD wouldn't hold all the ROM's, I started over.  I can't get the MAMEWah list generation function to work correctly.  In the MAME.ini file  if I choose "Rom Folder" I get a list of Rom names.  If I choose "rom Folder vs Listxml" I get nothing.  I hope somebody can help an old fart that doesn't like his cheese moved.     (edit) HMMM  Maybe the Lightspeed MAMElister?  Just found it below
« Last Edit: April 19, 2017, 04:03:54 pm by DrLarryE »
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
Re: I Know MAMEWah is Essentially Dead.....
« Reply #1 on: April 28, 2017, 10:23:22 pm »
The Mame xml format has changed since then. Mamewah cannot generate lists anymore. I now use a tool called RomLister to generate my lists.
https://www.waste.org/~winkles/ROMLister/
Hope it helps.
Pitou!
Pitou
« Reply #2 on: April 28, 2017, 10:30:38 pm »
