Author Topic: Microvetec Monitor issue  (Read 2469 times)
joeblade2
  • Last login:April 30, 2017, 07:19:58 pm
  • Scanline Generation!
« on: April 15, 2017, 12:02:40 pm »
Hi Guys, so decided to put my GM setup on my microvetec monitor, very little info exists on this monitor.
Running it in Generic mode VMMAKER, arcade_15 in mame ini.
Running into right edge squish and picture being off to the right and only taking up 2/3 of screen on a few games, most are fine!!
Have attached a couple of offenders:
joeblade2
Re: Microvetec Monitor issue
« Reply #1 on: April 24, 2017, 04:34:45 pm »
Hi guys, I know this hasn't been answered but just thought I'd put up another odd sizing issue i've just found...
Any help would be greatly appreciated on this fellas! :bump
  • Last login:Today at 02:45:53 am
« Reply #2 on: April 24, 2017, 05:31:46 pm »
Please use latest GM version. I suspect this issue was already fixed.
EDIT: I'm seeing the scaling options on mode switch was fixed in 0.016 alpha 5, the exact version you're using, so I'm not sure what's going on.
« Last Edit: April 24, 2017, 05:49:26 pm by Calamity »
joeblade2
« Reply #3 on: April 30, 2017, 07:19:59 pm »
Well if you don't know then it's probably not solvable Calamity.
Will upgrade to newer, older version of everything at some point and see if that fixes anything. :dunno
