Author Topic: Best (recommended) way to attach panels together  (Read 13625 times)
AlexFLA
  • Last login:June 25, 2017, 08:44:04 pm
  • What are you waiting for? Christmas?
« on: April 06, 2017, 10:56:45 pm »
Sorry for this lame question but after looking at many bartop arcade builds I figured that most, if not all, use battens/glue blocks to attach panels together. Is there a downside of using metal brackets to attach back panel to sides, as well as all other panels together? Is it harder, more expensive (you pay for each bracket), or there are reasons to not use something similar to this: http://www.homedepot.com/p/Simpson-Strong-Tie-ZMAX-18-Gauge-Galvanized-Steel-Angle-A21Z/100375047?
JDFan
Re: Best (recommended) way to attach panels together
« Reply #1 on: April 06, 2017, 11:17:24 pm »
Could be that the screws don't hold up so well in MDF - Tend to come loose after awhile - using the batons the screws only need to hold till the glue dries
Slippyblade
« Reply #2 on: April 07, 2017, 12:52:13 pm »
The glue connection is WAY stronger than the screw connection.  Then there is the cost.  Metal brackets, individually, are cheap.  2 dozen of them is spendy, especially compared to some rip cut wooded battens.
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #3 on: April 07, 2017, 03:12:12 pm »
PL premium 3x and wood battens... glue and air staple the battens in place... glue, clamp then staple the whole works. once the PL dries it won't be coming apart. it's sticks like baby crap on a wool blanket.
i would recommend against the PL premium 8x though, it's too thick for this type of application, even though it's like concrete when it's hardened. tried it once cause the store was out of 3x. really hard to work with.
morton
« Reply #4 on: April 08, 2017, 10:54:06 am »
I am starting a build and am not 100% what I will go with. Using ply over MDF would have given me a few more options, but the cost was too high in this case. I will likely use battens, glue and screws. It's true once glue dries, the screws don't do much... but it really helps in glue up, especially if you lack an abundance of large clamps.
The battens and glue should suffice. Construction adhesive if cost effective is OK, but if its much more expensive, you're better off saving a few $$$. Even using PVA wood glue is sufficient, because the glue ends up stronger than the actual wood its holding together. A proper glue joint will hold, and the wood is what gives if there is a break near it. The use of battens will provide more surface area for glue to hold onto, and will therefore be more sturdy if you are using plain sheet goods like MDF.
ugleymatt
  • Last login:October 11, 2022, 12:13:37 pm
« Reply #5 on: April 08, 2017, 06:15:02 pm »
I used pocket screws with my plywood build and its amazingly sturdy. Added woodglue as well just to help but not sure it was totally needed.
AlexFLA
« Reply #6 on: April 09, 2017, 10:16:24 am »
I bought several packs of brackets (were quite cheap due to small size required) as well as piece of wood which I'm going to use for battens. Also, I decided to try liquid nails vs gorilla wooden glue. So at the end I'm going to use the battens+glue+brackets to hold the whole thing together. Probably I'm not even going to use screws and nails for battens. Is there any recommendation against using liquid nails (it's much cheaper than wooden glue)?
Slippyblade
« Reply #7 on: April 10, 2017, 01:32:24 am »
I just use standard yellow wood glue, TiteBond to be exact.  Nothing special.
Qawsed11
  • Last login:September 23, 2017, 12:32:01 pm
  • Bartop maker and arcade restorer
« Reply #8 on: April 10, 2017, 12:10:42 pm »
I use wood glue, and a finish nail gun. Basically I consider the nails as just easy clamps to hold everything together until the glue sets. Screws are great too,  I would recommend countersinking them, and filling. Just make sure to pre drill. i also restore cabs and the ones that are glued or screwed are still strong 30 years later. I have a phoenix that was built useing brackets held and it's a mess.
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #9 on: May 29, 2017, 09:49:56 pm »
I spent close to 50 dollars on these steel brackets used to hold together deck beams for my pinball cab. They did not hold as well as I thought. I had 2 things going on that messed up my project. The first was I used wood thinner than 1/2 because I wanted it light. This caused me to have to use really shallow screws with my brackets to prevent the screw from going all the way through. The other thing was the brackets allowed for some flexing that I did not take into consideration when I built it. Basically thee whole box flexed. Wood glue might have helped but ultimately I decided that the structure was too weak for vigorous pinball and the wood was just too thin. The structure was so weak that when it came time to get rid of the parts I made I was able to pick it up and slam it on the ground causing it to explode into a pile of wood scrap.
If I was to do it again I would use 3/4 inch no matter what and use wood glue with the battens? I don't know what they are officially called.
bdn103
  • Last login:September 05, 2023, 09:29:59 pm
    • Classic Arcade Cabinets - FREE arcade cabinet build plans, printable PDFs and CNC plans
« Reply #10 on: June 07, 2017, 03:25:26 pm »
I use Kreg pocket screws and Titebond glue on everything.
Brian
« Reply #11 on: June 07, 2017, 04:00:06 pm »
Brian
Amen brother!!!
« Reply #12 on: June 07, 2017, 05:47:01 pm »
been thinking about picking up one of the kits but the want so damn much for them here. ($180 for the big kit and 60 for just the jig and bit)
morton
« Reply #13 on: June 08, 2017, 09:16:25 am »
Using battens and glue... First two I attached with screws... But tried a Brad gun yesterday. So much nicer. Less steps, and easier to undo mistakes with a few whacks of a mallet... For someone just learning I think that screws will drive you nuts... Lots of drilling and such... Not to say it doesn't have it's place.
Also, if cost freaks you out, think of value... I lack long clamps so the nail gun is pulling double duty at times keeping things tight while glue dries. Plus I borrowed it... So it's quite affordable ;)
bdn103
« Reply #14 on: June 08, 2017, 01:48:34 pm »
Yeah, price is brutal for the kit. It was something I agonized over and after buying it, I wished I had bought it years ago. The one I have is
https://www.amazon.com/Kreg-K4-Pocket-Hole-System/dp/B001DYFISG/ref=sr_1_7?ie=UTF8&qid=1496943714&sr=8-7&keywords=kreg
The generic drill bit and drivers work well. I have generics of both since I dropped the drill bit and broke the original tip..... also stripped the driver bit as well.
Brian
8BitMonk
« Reply #15 on: June 08, 2017, 03:11:59 pm »
That's overkill, the $40 kit is plenty good for this hobby. You could probably even get by with the $20 version if desperate to save cash, it'd just take a little longer.
https://www.amazon.com/Kreg-R3-Pocket-Hole-System/dp/B000J43A7W/ref=sr_1_2?s=power-hand-tools&ie=UTF8&qid=1496948717&sr=1-2&keywords=kreg+jig
« Reply #16 on: June 08, 2017, 08:47:49 pm »
Just buy the K4 and be done with it. Best $100 you'll ever spend.
atlsud
  • Last login:October 24, 2017, 04:28:32 pm
« Reply #17 on: October 09, 2017, 10:29:41 am »
Harbor freight sells a pocket hole jig for $65.  Apply a 20% coupon and it is only $52.  Comes with screws too.  Same as the Kreg but a lot cheaper.
