Author Topic: HELP: Conecting wires to USB Cable  (Read 2925 times)
Douek
  • Last login:May 06, 2017, 04:01:50 pm
« on: March 28, 2017, 03:24:11 pm »
Hi guys. I hope someone can help me here. Please forgive me if this is not the best place for my question. But I do see it as a restoration.
I have a pretty old arcade controller at home. I think it is made for Ps2. It has a 2nd conector that I don't even know for which console was made.
I would like to keep the Ps2 conector and replace the other one for a USB.
I need help to connect the wires properly.
My USB cable has the regular Red, Green, Black and White wires. I want to connect it to this part bellow. How should I do the wiring? Can anyone help me please?
  • Last login:Yesterday at 11:59:44 pm
Re: HELP: Conecting wires to USB Cable
« Reply #1 on: March 28, 2017, 09:22:55 pm »
Welcome aboard, Douek.   ;D
Please post pictures and the part number of the board you want to connect to USB, since that connector really doesn't give us anything to go on.   :dunno
« Last Edit: March 28, 2017, 09:40:07 pm by PL1 »
  • Online Online
  • Last login:Today at 12:44:27 am
« Reply #2 on: March 28, 2017, 09:29:15 pm »
^^^ He meant "Welcome aboard".
  • Bitches love Centipede
« Reply #3 on: March 28, 2017, 09:36:42 pm »
^^^ He meant "Arg, welcome aboard, matey".
%Bartop
Douek
« Reply #4 on: March 28, 2017, 11:57:42 pm »
Thx for helping me Scott.
Honestly I'm completely newbie on arcade cabinets. Just starting now
Let me try to get some pictures that may be helpful
This is the board inside my arcade cabinet:
As you can see, the conector in the 1st message of this topic plugs to this board.
I need to connect this plug to my USB cable so I can use my controller via USB on my Raspberry Pi3:
Does it help?
Best
« Reply #5 on: March 29, 2017, 12:22:40 am »
I don't recognize the board.  :dunno
Is there a manufacturer logo and/or part number on it?
Slippyblade
« Reply #6 on: March 29, 2017, 04:47:48 pm »
Keep in mind that simply swapping the plug probably won't work.  Different sockets expect different communications.  If it does work, woots for ya!
Douek
« Reply #7 on: March 30, 2017, 06:17:20 pm »
 :censored:
Sure. I have that in mind. I just decided to ask if its possible because of this video. It is in Portuguese, but the images speaks by itself
jimmyfloyd
  • Last login:April 04, 2025, 05:01:43 pm
« Reply #8 on: March 30, 2017, 10:41:38 pm »
Unless that board has a USB encoder on it someplace, I don't think you'll be able to attach it to the USB cable. USB has 4 wires, of which 1 is ground and 1 is +5V power. The other two are transmit and receive from the USB protocals.
If you knew what the pinout was for the wires of the plug (ie, what each one mapped to), if it was a one to one mapping with your buttons, then you could attach a USB encoder to it by wiring it properly, and get USB that way. Considering you have 14 microswitches (buttons + joystick) and that connector only has 9, I don't think you'll be so lucky...
« Reply #9 on: March 30, 2017, 11:04:21 pm »
What video?
Without more info to help us identify the board, there's nothing we can do to help you.  :dunno
Worst case scenario -- if we can't ID the current PCB, replace the current encoder with either a keyboard-style (I-Pac, etc.) or gamepad-style encoder. (Xin-Mo, ZD, etc.)
