Author Topic: Has anybody used Retropie with a Wei-Ya/MakVision 2929 SVGA CRT?  (Read 3660 times)
TGov
  • Last login:March 21, 2017, 02:07:54 pm
Pretty much that.  I have tried to se the config and using an HDMI to VGA converter but I still get the 'Out of Range' signal on boot.  Would love to use this in place of a full PC (which is a PIA to setup with the 2929 as well)
Any ideas or experience?
nitrogen_widget
TGov
Re: Has anybody used Retropie with a Wei-Ya/MakVision 2929 SVGA CRT?
« Reply #2 on: March 21, 2017, 02:08:27 pm »
It isn't a 15kz monitor, but maybe some of those setting will work.  Thanks.
langlem
  • Last login:May 27, 2025, 04:58:19 pm
« Reply #3 on: March 21, 2017, 11:27:14 pm »
I have a raspi, running retropie set up to a crt arcade monitor via an hdmi to vga adapter and it works great.
I am sorry, I am not near the cabinet to see exactly what monitor it is as its at my sons place... It has a vga hook up and I am fairly certain it was a Wells Gardner 19K3100...
Anyway, I simply went in and Opened config file and uncommented the hdmi_safemode to get it to boot into vgamode and after a restart it looks great.
Not sure if it would be that simple for you...but I am real interested to hear how it turns out because I have a line on that exact same monitor that I am considering for an upcoming project.
Good luck!
