Author Topic: groovymame 0183 - aviwrite issue  (Read 2656 times)
volaju
  • Last login:March 21, 2017, 02:09:14 pm
« on: March 15, 2017, 06:22:15 am »
Hi, I test  groovymame64_0183.017b.exe and encounter an issue, I never had on groovymame 0.164, with aviwrite:
1 Aviwrite is activated in my mame.ini, I launch any game (dodonpachi, viper phase for examples, not huge processor games)and after few minutes it start to slow down and freeze about every 5 seconds.
2 And when I quit the game, it take a lot of time (the much I played the much it take time) to exit  ???
3 The avi file is well recorded on my disk.
Did the aviwrite process change from 0.164 to 0.183?
(I don't mention inp and playback method because it never worked with groovymame for me, I don't trust)
My config:
G3258@4.2ghz
8go ram
Ati Radeon 5850 (latest CRT EMU DRIVER)
SSD disk
I would like to change to 0.183 but if I'm not able to record my play...  :(
« Last Edit: March 15, 2017, 06:38:30 am by volaju »
http://forum.shmup.com - shmup french community
Calamity
  • Moderator
  • Last login:Today at 09:50:38 am
  • Quote me with care
Re: groovymame 0183 - aviwrite issue
« Reply #1 on: March 15, 2017, 01:28:01 pm »
I assume you've checked that it works fine with baseline MAME, haven't you?
Steps to create a log:
volaju
« Reply #2 on: March 15, 2017, 01:47:47 pm »
No, I'll try mame 0.183 and check if I have the same issue ;)
volaju
« Reply #3 on: March 16, 2017, 07:26:32 am »
I found the problem, the games only slow down/freeze when I use "fast forward".
When I don't use it, no issue and exit in 2 seconds (not immediate as groovymame 0.164 but better).
But, I use "fast forward" because "throttle" don't work (it works on mame 0.183), normal?
Calamity
  • Moderator
« Reply #4 on: March 20, 2017, 05:44:28 pm »
-throttle only works on baseline because you're not using syncrefresh there, which is used by default with GM.
volaju
« Reply #5 on: March 21, 2017, 02:09:42 pm »
Thanks for the tip, I'll try that.
