Author Topic: Speed issue with sound pitching  (Read 3776 times)
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
« on: March 14, 2017, 10:00:25 pm »
Hello, I've recently switched to Groovymane 183 on a low lag LCD 1080p monitor.
I'm having an issue with every game I try where speed stays locked at 98%, sometimes jumps to 101% or 97% and when this occurs the sound pitches either higher or lower. This does not happen with other builds such as arcade64, vanilla mame, etc.
On the GM.ini the only changes I have are
Monitor_Type LCD
Video D3D
Frame_Delay 1
 What's causing this?
adder
Re: Speed issue with sound pitching
« Reply #1 on: March 14, 2017, 10:17:33 pm »
hi, does this problem occur if you load a game using groovymame which is a 60hz game?
« Last Edit: March 14, 2017, 10:22:06 pm by adder »
Trnzaddict
« Reply #2 on: March 14, 2017, 10:23:04 pm »
hi, does this problem occur if you load a game in mame which is a 60hz game?
Hi, not sure but the games I've tried that do this with are:
Alien Sector
Alien Syndrome
Aliens
Altered Beast
Galaga '88
I think they are 60hz games.
adder
« Reply #3 on: March 14, 2017, 10:40:30 pm »
what operating system are you using, windows 7?
ps. i'm guessing you did a quick test with setting frame_delay to 0 just to see if there was any difference?
Trnzaddict
« Reply #4 on: March 14, 2017, 10:43:58 pm »
Yes I'm on win 7. It does it on Win 8.1 too on my laptop.
Yes I tried it with no frame delay. Makes no difference.
adder
« Reply #5 on: March 14, 2017, 10:49:10 pm »
did you follow a guide at all, when getting set up, eg, a step by step guide,   if so could you post a link to the guide, thanks
adder
« Reply #6 on: March 14, 2017, 10:52:35 pm »
also, do you know how to generate a log, when you run a game
if you could do that (any game is fine), and attach the log here with your post, that would be really helpful:
______________________________________________________________
Reporting problems:-
   How to create a log:
If you're experiencing any problem or odd behaviour regarding GroovyMAME, please create a log and post it when reporting the problem. This will provide us with critical information beforehand and will save us from asking you to post a log. Bug reports without a proper log will be ignored.
- Run GroovyMAME like this:
c:\mame_folder>groovymame.exe romname -v >romname.txt- Upload romname.txt as an attachment to your post. Please don't paste it inside the edit box as it makes things unreadable.
Trnzaddict
« Reply #7 on: March 14, 2017, 11:01:59 pm »
No problem, cab is off for the night. I'll get you a log tomorrow.
No I never followed a guide. I asked a few months ago if I could utilize groovymame to lower input lag even though I'm not using a CRT, Calamity responded sure, just set the monitor to LCD and use d3d9ex builds.
I read the user Haynor reporting the same exact problem I'm having at the beginning of the Groovymame thread. Calamity stated it had something to do with timing code used in C++ and that he/she sorta fixed it with newer builds but my problem almost sounds like something set wrong  in the ini.
Regardless I'll generate a lot tomorrow for you guys to look at. Thanks for the help so far :)
adder
« Reply #8 on: March 14, 2017, 11:55:36 pm »
he  :)
cool ok, yep get the log posted to be on the safe side and increase the chances for the experts here to get you all fixed up   ;D
Trnzaddict
« Reply #9 on: March 22, 2017, 10:18:19 am »
Hello again. I don't know what happened, but I created a new mame.ini before attempting a log and the issue has seemed to go away. Strange but it's fixed.
Something might of been off in the ini.
