Author Topic: [SOLVED] Samsung A68KVL74X Kortek KT2914F Vert Collapse?  (Read 3632 times)
robertblue3
  • Last login:August 08, 2025, 05:43:11 pm
« on: March 14, 2017, 05:31:55 pm »
Hello all,
I am having a problem with my CRT monitor in a PGA Tour Golf Cabinet. I am not sure where to begin.
Powers up but has what I believe is vertical collapse.
See pictures. There is no input attached with the picture taken.
« Last Edit: March 23, 2017, 11:41:43 am by robertblue3 »
grantspain
Re: Samsung A68KVL74X Kortek KT2914F Vert Collapse?
« Reply #1 on: March 15, 2017, 08:40:13 am »
common fault-vertical ic,a fair few resistors in the vertical circuit and a couple of caps
this information is readily available online
robertblue3
« Reply #2 on: March 15, 2017, 05:45:00 pm »
thanks for the information grantspain.
after a more refined internet search now that I knew what I was looking for, I've ordered a new IC201 (TDA8172) and a cap kit. While I wait for the parts to arrive, I'll ensure the resisters in the vertical circuit are not degraded by pulling them and checking with my meter.
I'll post my results after the new components are installed.
robertblue3
« Reply #3 on: March 23, 2017, 11:37:44 am »
I've replaced IC201 and all radial capacitors and it has brought my monitor back to life. Still needs an alignment and focus adjustment but I'm happy to have it back.
Thanks for your help, grantspain! My next project is a Makvision 2929D, which I might need some additional help with.
Eric
grantspain
Re: [SOLVED] Samsung A68KVL74X Kortek KT2914F Vert Collapse?
« Reply #4 on: March 24, 2017, 05:29:02 am »
your issue with the corners and convergence are most likely down to the deflection coil,they all seem to burn out on these monitors-they go brittle and start to break apart
