Author Topic: Paint as an option on MDF..........?  (Read 2081 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: January 25, 2004, 09:52:47 pm »
I started off as being gung-ho to do my whole cab in laminate, but my enthusiasm has worn.
I'm considering painting the base half of my UAII.  (MDF)
My CP will be laminated, but the next area of concern is the "foot" area when sitting at the cab on bar stools.
Would the finish be durable enough to take the odd kick?
Is one type of paint better than another?
A "plastic" paint perhaps? (I've seen paint where there appears to be some sort of plastic compound IN the paint itself)
%$#@!&* machine took my quarter!
Generic Eric
Re:Paint as an option on MDF..........?
« Reply #1 on: January 25, 2004, 10:02:24 pm »
You could cover the MDF with a Plexi kick plate
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #2 on: January 25, 2004, 10:15:05 pm »
I used a floor and porch paint figuring it'd be really durable. It looks awesome, but seems as soft as a normal interior latex. It scratches pretty easy. I may cover with clearcoat after I apply artwork.
Anyway, the reason for my post is to suggest that you select your paint carefully. I'd suggest Rustoleum's enamel paints. I used some this summer on something else and it came out super durable, hard, glossy, and seemingly indestructable. I was really impressed. Clean-up was a mess though (not water-based).
Good luck!
- Patrick
NoOne=NBA=
« Reply #3 on: January 25, 2004, 10:58:12 pm »
I used flat black, covered with "granite" spatter paint, covered with 2 layers of Matte Clear on mine, and haven't had ANY problem with it at all.
The white/gray spattering in the granite paint helps hide any shoe marks you might get as well.
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #4 on: January 26, 2004, 08:57:00 am »
i second the vote for rustoleum industrial enamel. its some pretty tough stuff.
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #5 on: January 26, 2004, 10:03:01 am »
I would suggest using the black rubber kick plates that are commonly used for kitchen cabinets.  You can buy them cheap at lowes and home depot and they last a long time.  I put them on my cocktail cab and they work great.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #6 on: January 26, 2004, 10:08:09 am »
  Lighten up there, son! You'll be uber-happy once you get passed those boring parts. When you've never built one of these before, it's hard to see the whole picture. When I was at that point, I remember thinking that my arcade was never going to get done.. but there I was this morning playing a sweet game of Final Fight! *drool*
  I used plain old black semi-gloss paint with about 6 or 7 coats of paint. Other than dirt or dust, I don't see there being a real problem.  It WILL get dirty though, and it WILL get scuffed up from people getting excited and stepping all over it, or whatever. No matter what you do, you'll eventually have to replace a kickplate or repaint at some point. Just accept it :)
  Personally, I'm not too worried about it. Should I be? Probably, but a metal or plexiglass kickplate is something I can install whenever I want and doesn't need to be installed when I'm building the cabinet. I'll see what my wear-and-tear will be first.
/Steve
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #7 on: January 26, 2004, 11:13:28 am »
I did mine in high gloss indoor wall paint.
Did 2 (maybe 3) coats.  it holds up to me kicking the crap out of it with my soft Chuck Taylors.  If you're a Steel toed Doc Martins kinda guy...you might want to build the machine out of steel.  At least the front panel.  ;)
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
Stingray
« Reply #8 on: January 26, 2004, 01:09:46 pm »
I'll be painting mine in the next couple of weeks. Being that I have access to a professional auto paint shop, I'll be painting mine with two part urethane automotive paint. Overkill? Maybe, but it will be a serously tough finish. This doesn't mean it won't get scuffed & scratched from enthusiastic play, but it will be alot more durable than latex or enamel.
-S
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #9 on: January 26, 2004, 03:39:56 pm »
If you want a really tough paint use automotive epoxy paint. We paint our test lab machines with it and it resists chips in the paint on steel tubing when we drop wrenches and screwdrivers on them.
My cab is painted with sprayed gloss enamel.
I would recommend anything but RUSTOLEUM.
I hate working with that slow drying, sagging, dripping, running crap...
My next cab will be rolled with Hammerite. I love that hammered finish look.
