Author Topic: vertical.ini  (Read 3280 times)
tom5151
  • Last login:September 16, 2023, 09:21:11 am
vertical.ini
« on: March 05, 2017, 11:42:29 am »
Hi all,
I used to have a vertical.ini in GM containing:
interlace                 0
doublescan                0
Since GM 0.182, on vertical games with these settings, the scrolling is different than before and not very playable.
I don't know how to explain it, but there are some vertical lines every 0.5 inch.
I tried to make a video. Hope you'll see the problem, cause the video quality is not that good, sorry.
  • Last login:Today at 01:38:17 pm
Re: vertical.ini
« Reply #1 on: March 05, 2017, 12:04:14 pm »
Usually you get a log and see whats going on.
tom5151
Re: vertical.ini
« Reply #2 on: March 06, 2017, 12:02:34 pm »
Sorry, here is the log:
SwitchRes: v0.017b, Monitor: arcade_15, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15625.00-16200.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
SwitchRes: \\.\DISPLAY1: AMD Radeon HD 7800 Series (PCI\VEN_1002&DEV_679E&SUBSYS_E246174B&REV_00)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{6E8DB273-46D2-4C2A-B55E-628D55C0600E}\0000
ATI/AMD ADL init
Catalyst Version 15.8
ADL functions retrieved successfully.
Switchres: Searching for custom video modes...
Switchres: [  1]  240x 200 @ 60 : ATI ADL timing "240x200_60 15.656000KHz 59.984673Hz" 5.010000 240 256 280 320 200 222 225 261   -hsync -vsync
Switchres: [  2]  248x 192 @ 60 : ATI ADL timing "248x192_60 15.670000KHz 60.038315Hz" 5.140000 248 264 288 328 192 218 221 261   -hsync -vsync
Switchres: [  3]  256x 192 @ 60 : ATI ADL timing "256x192_60 15.654000KHz 59.977013Hz" 5.260000 256 272 296 336 192 218 221 261   -hsync -vsync
Switchres: [  4]  256x 224 @ 60 : ATI ADL timing "256x224_60 15.654000KHz 59.977013Hz" 5.260000 256 272 296 336 224 234 237 261   -hsync -vsync
Switchres: [  5]  256x 239 @ 60 : ATI ADL timing "256x239_60 15.654000KHz 59.977013Hz" 5.260000 256 272 296 336 239 241 244 261   -hsync -vsync
Switchres: [  6]  256x 240 @ 60 : ATI ADL timing "256x240_60 15.654000KHz 59.977013Hz" 5.260000 256 272 296 336 240 242 245 261   -hsync -vsync
Switchres: [  7]  256x 244 @ 60 : ATI ADL timing "256x244_60 15.833000KHz 59.973484Hz" 5.320000 256 272 296 336 244 245 248 264   -hsync -vsync
Switchres: [  8]  320x 224 @ 60 : ATI ADL timing "320x224_60 15.660000KHz 60.000000Hz" 6.640000 320 336 368 424 224 234 237 261   -hsync -vsync
Switchres: [  9]  320x 240 @ 60 : ATI ADL timing "320x240_60 15.660000KHz 60.000000Hz" 6.640000 320 336 368 424 240 242 245 261   -hsync -vsync
Switchres: [ 10]  320x 244 @ 60 : ATI ADL timing "320x244_60 15.849000KHz 60.034092Hz" 6.720000 320 336 368 424 244 245 248 264   -hsync -vsync
Switchres: [ 11]  320x 256 @ 58 : ATI ADL timing "320x256_58 16.202000KHz 58.490974Hz" 6.870000 320 336 368 424 256 258 261 277   -hsync -vsync
Switchres: [ 12]  320x 512 @ 58 : ATI ADL timing "320x512_58 16.226000KHz 58.472073Hz" 6.880000 320 336 368 424 512 515 521 555 interlace  -hsync -vsync
Switchres: [ 13]  336x 224 @ 60 : ATI ADL timing "336x224_60 15.659000KHz 59.996170Hz" 6.890000 336 352 384 440 224 234 237 261   -hsync -vsync
Switchres: [ 14]  336x 288 @ 52 : ATI ADL timing "336x288_52 16.204000KHz 52.440128Hz" 7.130000 336 352 384 440 288 290 293 309   -hsync -vsync
Switchres: [ 15]  384x 224 @ 60 : ATI ADL timing "384x224_60 15.654000KHz 59.977013Hz" 7.890000 384 400 440 504 224 234 237 261   -hsync -vsync
Switchres: [ 16]  384x 240 @ 60 : ATI ADL timing "384x240_60 15.654000KHz 59.977013Hz" 7.890000 384 400 440 504 240 242 245 261   -hsync -vsync
Switchres: [ 17]  512x 448 @ 60 : ATI ADL timing "512x448_60 15.692000KHz 60.007648Hz" 10.420000 512 536 584 664 448 467 473 523 interlace  -hsync -vsync
Switchres: [ 18]  512x 478 @ 60 : ATI ADL timing "512x478_60 15.692000KHz 60.007648Hz" 10.420000 512 536 584 664 478 482 488 523 interlace  -hsync -vsync
Switchres: [ 19]  544x 242 @ 60 : ATI ADL timing "544x242_60 15.716000KHz 59.984734Hz" 11.190000 544 568 624 712 242 243 246 262   -hsync -vsync
Switchres: [ 20]  640x 256 @ 58 : ATI ADL timing "640x256_58 16.202000KHz 58.490974Hz" 13.740000 640 672 736 848 256 258 261 277   -hsync -vsync
Switchres: [ 21]  640x 480 @ 60 : ATI ADL timing "640x480_60 15.685000KHz 59.980881Hz" 13.050000 640 664 728 832 480 483 489 523 interlace  -hsync -vsync
Switchres: [ 22]  640x 480 @ 30* : ATI ADL timing "640x480_30 15.685000KHz 59.980881Hz" 13.050000 640 664 728 832 480 483 489 523 interlace  -hsync -vsync
Switchres: [ 23]  640x 512 @ 58 : ATI ADL timing "640x512_58 16.226000KHz 58.472073Hz" 13.760000 640 672 736 848 512 515 521 555 interlace  -hsync -vsync
Switchres: [ 24]  664x 496 @ 60 : ATI ADL timing "664x496_60 16.169000KHz 59.996288Hz" 14.100000 664 696 760 872 496 499 505 539 interlace  -hsync -vsync
Switchres: [ 25] 2560x 216 @ 60 : ATI ADL timing "2560x216_60 15.661000KHz 60.003830Hz" 52.120000 2560 2664 2912 3328 216 230 233 261   -hsync -vsync
Switchres: [ 26] 2560x 224 @ 60 : ATI ADL timing "2560x224_60 15.661000KHz 60.003830Hz" 52.120000 2560 2664 2912 3328 224 234 237 261   -hsync -vsync
Switchres: [ 27] 2560x 239 @ 60 : ATI ADL timing "2560x239_60 15.661000KHz 60.003830Hz" 52.120000 2560 2664 2912 3328 239 241 244 261   -hsync -vsync
Switchres: [ 28] 2560x 240 @ 60 : ATI ADL timing "2560x240_60 15.661000KHz 60.003830Hz" 52.120000 2560 2664 2912 3328 240 242 245 261   -hsync -vsync
Switchres: [ 29] 2560x 242 @ 60 : ATI ADL timing "2560x242_60 15.721000KHz 60.003819Hz" 52.320000 2560 2664 2912 3328 242 243 246 262   -hsync -vsync
Switchres: [ 30] 2560x 248 @ 60 : ATI ADL timing "2560x248_60 16.139000KHz 59.996281Hz" 54.230000 2560 2672 2928 3360 248 250 253 269   -hsync -vsync
Switchres: [ 31] 2560x 256 @ 58 : ATI ADL timing "2560x256_58 16.199000KHz 58.480145Hz" 54.430000 2560 2672 2928 3360 256 258 261 277   -hsync -vsync
Switchres: [ 32] 2560x 264 @ 57 : ATI ADL timing "2560x264_57 15.733000KHz 55.397888Hz" 52.360000 2560 2664 2912 3328 264 265 268 284   -hsync -vsync
Switchres: [ 33] 2560x 272 @ 55 : ATI ADL timing "2560x272_55 16.199000KHz 55.286690Hz" 54.430000 2560 2672 2928 3360 272 274 277 293   -hsync -vsync
Switchres: [ 34] 2560x 280 @ 54 : ATI ADL timing "2560x280_54 16.199000KHz 53.817276Hz" 54.430000 2560 2672 2928 3360 280 282 285 301   -hsync -vsync
Switchres: [ 35] 2560x 288 @ 52 : ATI ADL timing "2560x288_52 16.199000KHz 52.423946Hz" 54.430000 2560 2672 2928 3360 288 290 293 309   -hsync -vsync
Switchres: [ 36] 2560x 448 @ 60 : ATI ADL timing "2560x448_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 448 467 473 523 interlace  -hsync -vsync
Switchres: [ 37] 2560x 464 @ 60 : ATI ADL timing "2560x464_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 464 475 481 523 interlace  -hsync -vsync
Switchres: [ 38] 2560x 480 @ 60 : ATI ADL timing "2560x480_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 480 483 489 523 interlace  -hsync -vsync
Switchres: [ 39] 2560x 496 @ 60 : ATI ADL timing "2560x496_60 16.169000KHz 59.996288Hz" 54.330000 2560 2672 2928 3360 496 499 505 539 interlace  -hsync -vsync
SwitchRes: Found 39 custom of 39 active video modes
SwitchRes: -resolution was forced as 2560x0
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.017b:[raiden2] Calculating best video mode for 240x320@55.407803 orientation: rotated
SwitchRes: [ 240]x[ 200]_(60=59.984673Hz) - locked
SwitchRes: [ 248]x[ 192]_(60=60.038315Hz) - locked
SwitchRes: [ 256]x[ 192]_(60=59.977013Hz) - locked
SwitchRes: [ 256]x[ 224]_(60=59.977013Hz) - locked
SwitchRes: [ 256]x[ 239]_(60=59.977013Hz) - locked
SwitchRes: [ 256]x[ 240]_(60=59.977013Hz) - locked
SwitchRes: [ 256]x[ 244]_(60=59.973484Hz) - locked
SwitchRes: [ 320]x[ 224]_(60=60.000000Hz) - locked
SwitchRes: [ 320]x[ 240]_(60=60.000000Hz) - locked
SwitchRes: [ 320]x[ 244]_(60=60.034092Hz) - locked
SwitchRes: [ 320]x[ 256]_(58=58.490974Hz) - locked
SwitchRes: [ 320]x[ 512]_(58=58.472073Hz) - locked
SwitchRes: [ 336]x[ 224]_(60=59.996170Hz) - locked
SwitchRes: [ 336]x[ 288]_(52=52.440128Hz) - locked
SwitchRes: [ 384]x[ 224]_(60=59.977013Hz) - locked
SwitchRes: [ 384]x[ 240]_(60=59.977013Hz) - locked
SwitchRes: [ 512]x[ 448]_(60=60.007648Hz) - locked
SwitchRes: [ 512]x[ 478]_(60=60.007648Hz) - locked
SwitchRes: [ 544]x[ 242]_(60=59.984734Hz) - locked
SwitchRes: [ 640]x[ 256]_(58=58.490974Hz) - locked
SwitchRes: [ 640]x[ 480]_(60=59.980881Hz) - locked
SwitchRes: [ 640]x[ 480]_[30=59.980881Hz] - locked
SwitchRes: [ 640]x[ 512]_(58=58.472073Hz) - locked
SwitchRes: [ 664]x[ 496]_(60=59.996288Hz) - locked
SwitchRes: [2560]x[ 216]_(60=60.003830Hz)
   rng(0): 2560 x 216_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.675)
SwitchRes: [2560]x[ 224]_(60=60.003830Hz)
   rng(0): 2560 x 224_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.700)
SwitchRes: [2560]x[ 239]_(60=60.003830Hz)
   rng(0): 2560 x 239_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.747)
SwitchRes: [2560]x[ 240]_(60=60.003830Hz)
   rng(0): 2560 x 240_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.750)
SwitchRes: [2560]x[ 242]_(60=60.003819Hz)
   rng(0): 2560 x 242_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.756)
SwitchRes: [2560]x[ 248]_(60=59.996281Hz)
   rng(0): 2560 x 248_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.775)
SwitchRes: [2560]x[ 256]_(58=58.480145Hz)
   rng(0): 2560 x 256_55.407803p 15.625000 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.800)
SwitchRes: [2560]x[ 264]_(57=55.397888Hz)
   rng(0): 2560 x 264_55.407803p 15.735816 [fract] scale(7, 1, 1) diff(16.67, 0.00, 0.0000) ratio(10.667, 0.825)
SwitchRes: [2560]x[ 272]_(55=55.286690Hz)
   rng(0): 2560 x 272_55.290104p 16.200000 [fract] scale(7, 1, 1) diff(16.67, 0.00, -0.1177) ratio(10.667, 0.850)
SwitchRes: [2560]x[ 280]_(54=53.817276Hz)
   rng(0): 2560 x 280_53.820599p 16.200000 [fract] scale(7, 1, 1) diff(16.67, 0.00, -1.5872) ratio(10.667, 0.875)
SwitchRes: [2560]x[ 288]_(52=52.423946Hz)
   rng(0): 2560 x 288_52.427185p 16.200000 [fract] scale(7, 1, 1) diff(16.67, 0.00, -2.9806) ratio(10.667, 0.900)
SwitchRes: [2560]x[ 448]_(60=60.003822Hz)
   rng(0):  out of range
SwitchRes: [2560]x[ 464]_(60=60.003822Hz)
SwitchRes: [2560]x[ 480]_(60=60.003822Hz)
SwitchRes: [2560]x[ 496]_(60=59.996288Hz)
SwitchRes: [raiden2] (1) vertical (240x320@55.407803)->(2560x264@55.407803)
SwitchRes: Modeline "2560x264_57 15.735816KHz 55.407803Hz" 52.368796 2560 2664 2912 3328 264 265 268 284   -hsync -vsync
Switchres: saving    ATI ADL timing "2560x264_57 15.733000KHz 55.397888Hz" 52.360000 2560 2664 2912 3328 264 265 268 284   -hsync -vsync
Switchres: updating  ATI ADL timing "2560x264_57 15.735816KHz 55.407803Hz" 52.368796 2560 2664 2912 3328 264 265 268 284   -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -noautoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -unevenstretch
SwitchRes: Setting option -nounevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nofilter
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9Ex
Physical width 640, height 480
Direct3D: Initialize
Direct3D: Configuring adapter #0 = AMD Radeon HD 7800 Series (CRT Emudriver)
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 679E
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 2560x264
Direct3D: First scanline: 19, Last scanline: 283, Break scanline: 283, Delay scanline: -9
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
RawInput: APIs detected
PortAudio: API MME has 4 devices
PortAudio: MME: "Microsoft Sound Mapper - Output"
PortAudio: MME: "Speakers (High Definition Audio" (default)
PortAudio: MME: "Digital Audio (S/PDIF) (High De"
PortAudio: API Windows DirectSound has 4 devices
PortAudio: Windows DirectSound: "Primary Sound Driver" (default)
PortAudio: Windows DirectSound: "Speakers (High Definition Audio Device)"
PortAudio: Windows DirectSound: "Digital Audio (S/PDIF) (High Definition Audio Device)"
PortAudio: API Windows WASAPI has 3 devices
PortAudio: Windows WASAPI: "Speakers (High Definition Audio Device)" (default)
PortAudio: Windows WASAPI: "Digital Audio (S/PDIF) (High Definition Audio Device)"
PortAudio: API Windows WDM-KS has 3 devices
PortAudio: Windows WDM-KS: "Speakers (HD Audio Speaker)" (default)
PortAudio: Windows WDM-KS: "SPDIF Out (HD Audio SPDIF out 2)"
PortAudio: Windows WDM-KS: "SPDIF Out (HD Audio SPDIF out)"
PortAudio: Using device "Speakers (High Definition Audio Device)" on API "Windows WASAPI"
PortAudio: Sample rate is 48000 Hz, device output latency is 3.33 ms
PortAudio: Allowed additional buffering latency is 10.00 ms/480 frames
Input: Adding keyboard #0: HID Keyboard Device (device id: \\?\HID#VID_046D&PID_C52B&MI_00#7&15cacfba&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #1: Standard PS/2 Keyboard (device id: \\?\ACPI#MSFT0001#4&1a426706&0#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C52B&MI_01&Col01#7&29ab37c&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C52B&MI_01&Col01#7&29ab37c&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Region ':maincpu' created
unzip: opened archive file D:\HFSBox15K\Roms\ShmupMame\raiden2.zip
unzip: found D:\HFSBox15K\Roms\ShmupMame\raiden2.zip ECD
unzip: D:\HFSBox15K\Roms\ShmupMame\raiden2.zip has no ZIP64 ECD locator
unzip: read D:\HFSBox15K\Roms\ShmupMame\raiden2.zip central directory
unzip: closing archive file D:\HFSBox15K\Roms\ShmupMame\raiden2.zip and sending to cache
unzip: found D:\HFSBox15K\Roms\ShmupMame\raiden2.zip in cache
Region ':user2' created
Region ':audiocpu' created
Region ':gfx1' created
Region ':gfx2' created
Region ':gfx3' created
Region ':oki1' created
Region ':oki2' created
Region ':pals' created
jj4b02__ami18cv8-15.u0342.jed NOT FOUND (NO GOOD DUMP KNOWN) (tried in raiden2 raiden2)
WARNING: the machine might not run correctly.
Starting Raiden II (US, set 1) ':'
  (missing dependencies; rescheduling)
Starting V30 ':maincpu'
Starting Z80 ':audiocpu'
Starting Video Screen ':screen'
Optional device ':screen:finder_dummy_tag' not found
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Seibu CRT Controller ':crtc'
Starting Seibu COP (Raiden 2) ':raiden2cop'
Starting Speaker ':mono'
Starting YM2151 ':ymsnd'
Starting OKI6295 ':oki1'
Starting OKI6295 ':oki2'
Starting Seibu Sound System ':seibu_sound'
hiscore: found hiscore.dat entry for raiden2
hiscore: scores read
Average speed: 99.98% (38 seconds)
Switchres: restoring ATI ADL timing "2560x264_57 15.733000KHz 55.397888Hz" 52.360000 2560 2664 2912 3328 264 265 268 284   -hsync -vsync
ATI/AMD ADL close
Sound: overflows=1 underflows=1
Re: vertical.ini
« Reply #3 on: March 07, 2017, 01:42:45 pm »
Hi tom5151,
Ok, the log is exactly the same as the one I'm getting here replicating your configuration. And I'm not seeing anything wrong on my screen playing raiden2.
Which version are you comparing this one with?
I'm not sure what's the issue by seeing your video. There some pretty obvious interferences running diagonally that might be an effect from the camera and create the ilusion(?) that the trees don't move up evenly, but in separate columns.
There's another artifact that's caused by downscaling. Forcing this game at 264 lines causes visible artifacts that affect scrolling.
I'm not sure if it's any of these issues what you're seeing.
tom5151
Re: vertical.ini
« Reply #4 on: March 09, 2017, 01:03:56 pm »
Hi tom5151,
My bad, I made some tests with crt emu b8, with older GM version and it's the same, I have the issue.
It's not easy to explain. Let's forget about diagonal interferences, it's indeed camera recording illusions.
It's in fact that the trees move in separate stacks (let's say 0.5 inch height).
I tried to make another video, but not sure it's better.
