Author Topic: Seem to have lost super resolutions  (Read 2981 times)
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« on: February 28, 2017, 09:45:56 pm »
I updated to the the latest beta of crt emu driver on my hd 6870 and loved it. I then installed a radeon  r9 380 and everything seemed great. Cemu and dolphin were running better than ever. However groovymame failed to come close to an accurate resolution for mortal Kombat. When I looked at my resolution list with quickres.exe I noticed that I don't have any of my super resolutions, I can only go as high as 640x480, and I have 3 instances of each resolution I do have installed. When I generate my modes and install them using the latest tools everything seems to go well. but they simply are not there. I also notice that overtime I install a mode my display numbers change. Calamity any ideas?
buttersoft
  • Last login:Today at 02:01:17 am
  • Is running at 15kHz
Re: Seem to have lost super resolutions
« Reply #1 on: February 28, 2017, 10:28:04 pm »
Does ArcadeOSD (from the crt_emudriver package) show the same thing as Quickres? You're always using the same monitor? EDID emulation working ok?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #2 on: March 01, 2017, 02:01:49 am »
Don't worry about this.. it's normal
Reboot, and the display number will start over again...
  • Last login:February 19, 2026, 06:15:36 am
« Reply #3 on: March 01, 2017, 02:25:25 am »
As I mentioned in another thread there's an issue with the newer cards (e.g. 380) being detected as legacy cards, thats why they're causing problems. I'll have a fix for the weekend probably.
androtaz08
« Reply #4 on: March 01, 2017, 02:29:25 pm »
You're  the best calamity!!
