Author Topic: Best Pushbuttons for "Admin" Actions?  (Read 2978 times)
thameslives
  • Last login:February 27, 2017, 02:49:26 pm
« on: February 27, 2017, 01:28:30 pm »
Hi,
I built my cabinet using the Suzo Happ pushbutton bundle set they sell on Amazon.  Now I'd like to add some smaller buttons for "admin" stuff - volume up/down, game saves, etc.  Does anyone have a favorite?  I'm not looking for something backlit, just a button that's similar to the standard pushbutton (same type of micro-switch, same depth for control panel install), just something smaller in diameter (or even rectangular).
Brian
« Last Edit: February 27, 2017, 02:26:19 pm by thameslives »
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Re: Best Pushbuttons for "Admin" Actions?
« Reply #1 on: February 27, 2017, 11:19:08 pm »
What are you using for an encoder?  Alot of them have "shift" keys where you can use the same button for different tasks.
thewisteron
  • Last login:May 03, 2020, 08:04:40 pm
« Reply #2 on: February 28, 2017, 12:02:51 am »
I used normal sized buttons for my admin, but I've always liked the little buttons they use on the Surface Tension machines. Not sure where they get them from though: http://www.surface-tension.net/external/byoac/st4_panel.jpg
adder
« Reply #3 on: February 28, 2017, 12:58:47 am »
i'd be interested in some good answers on this subject, as in the past i used the ones like in the pic below.  bad idea.. they suck, and eventually hurt your fingers!  (in my opinion they would only be good for something where u very rarely have to press it).
  • Last login:Today at 12:10:14 am
« Reply #4 on: February 28, 2017, 08:24:27 am »
I really like these  low-profile black-rimmed buttons (Rick is the only vendor I've found that stocks these  :cheers:) with inkjet printed inserts on Avery 18665 or 8665 labels.
The ring between the nut and bezel is removable.
There are many vendors that carry translucent-rimmed or "sawed-off volcano" LED buttons.
I usualy get 12v LEDs and power them with 5v -- not as bright and much longer lasting.  ;D
PROTIP: Get white LEDs for yellow buttons -- yellow LED + yellow diffuser = muddy orange. :puke
If you're looking for a smaller diameter non-LED button, there are some options but these won't mount without routing a pocket on the back of a 3/4" panel.  IIRC Paradise Arcade Shop and/or Focus Attack carry these.
Seimitsu PS-14-GN-C -- 24mm convex, threaded, clear cover
Sanwa OBSN-24 -- 24mm convex, threaded
Seimitsu PS-14-DN -- 20mm convex, threaded
Sanwa SDM-20 -- 20mm concave, locking tabs
Sanwa SDM-18 -- 18mm concave, locking tabs
Divemaster has these but they're intended for a service panel mounted behind your coin door.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #5 on: February 28, 2017, 02:09:35 pm »
I use 1 of these as a "shift" button.... they do kinda suck. But they are small and easily hide-able and the stiffness makes it less prone to accidental pressing(mounted behind volume knob).
haynor666
  • retro maniac
« Reply #6 on: March 05, 2017, 05:55:14 am »
I use Sanwa 24 since I use 30 size version for play my panel looks quite nice with all buttons the same colour and style.
