Author Topic: What to buy for a MAME control panel (EU)  (Read 4801 times)
Raitsa
  • Last login:March 29, 2024, 10:45:35 am
« on: February 26, 2017, 11:12:35 am »
Hi guys.
I am going to finish a control panel for the cabinet below.
I have been using an X-Arcade as a temporary solution for a long time but now its time for something better.
Thinking of these:
2 joysticks
trackball
12 buttons in total for both player 1 and 2
1 Player button
2 Players button
Pinball buttons on the sides
USB-cable connection to the PC instead of ps2
I am located in Finland, so EU is preferred to buy from.
I only play MAME stuff.
So, what do I need and where should i buy em from?
Using a modern PC with the latest MAME + Win10.
Intel I7-2600K, Akasa Freedom Multi platform cooler
Gainward GTX 980 Triple fan
Crucial M4 256GB SSD
Asus P8P67 PRO B3
Kingston Hyper X Blu DDR3 12gb
Chieftec ATX 750W PFC
Cooler master HAF-X
« Last Edit: March 03, 2017, 02:38:05 pm by Raitsa »
paigeoliver
  • Awesome face!
Re: What to buy for a MAME control panel (EU)
« Reply #1 on: February 26, 2017, 02:10:18 pm »
If you only play Mame then you only need 6 buttons per player and not 8.
Raitsa
« Reply #2 on: February 26, 2017, 02:30:10 pm »
Thanks paigeoliver, ok, edited my question to 6.
  • Last login:Today at 04:28:07 am
« Reply #3 on: February 27, 2017, 05:22:43 am »
Thinking of these:
2 joysticks
trackball
1 Player button
2 Players button
There are many fine vendors to choose from, but it's hard to go wrong with Ultimarc.
Encoder: Either the Mini-PAC (comes with a pre-fab wiring harness) or I-PAC.
Trackball: The U-Trak is plug-and-play with either encoder above.
Pinball buttons: Check out the GoldLeaf buttons.
Remember that these pushbuttons have 2.8mm Quick Disconnect tabs while many other buttons have 4.8mm tabs.
Joysticks and other buttons: Depends on your game list and personal preferences.   :dunno
What games/genres do you play the most?  SHMUPS?  Fighting games?  Games from the '80s?
EDIT:  By "USB-cable connection", do you mean that you want the encoder to connect via USB (not PS/2) or do you want an external USB connector so you can connect a gamepad for console games.
« Last Edit: February 27, 2017, 05:31:15 am by PL1 »
Raitsa
« Reply #4 on: February 27, 2017, 06:18:42 am »
Thanks a lot PL1, USB meaning usb to pc connection preferred over ps2.
No need for consoles or gamepads.
I prefer the oldies from the 80's but Raitsa jr, at 7 years, might prefer other games than the old man.
keilmillerjr
  • Web Developer.
« Reply #5 on: February 27, 2017, 07:32:56 am »
Ultimarc is in England. Look on their website.
Pro tip: Your cabinet is for arcade, not dishes. Get rid of those lame drawers and doors.
Automark
  • Arcade in Spain ?
« Reply #6 on: February 28, 2017, 01:45:13 pm »
I ordered always in germany @ http://www.arcadeshop.de
Raitsa
« Reply #7 on: March 01, 2017, 10:35:45 am »
This is how my shopping cart looks now at Ultimarc, looking ok to you guys so far?
So, now maybe the most important things left to choose: joysticks.
Which ones do you guys recommend?
Titchgamer
« Reply #8 on: March 01, 2017, 01:38:58 pm »
Depends on you and what you want to play.
There are many answers to that question LOL
Raitsa
« Reply #9 on: March 02, 2017, 01:13:35 pm »
I think i am gonna go with these, is this everything thats needed?
Trackball is  left out on purpose for now.
Osirus23
« Reply #10 on: March 02, 2017, 02:12:34 pm »
That's a really fancy and expensive stick. Do you really need the analog features? If you just need a normal stick that 99% of games will use you can buy a regular switch kind and wire it to that Mini-PAC.
Raitsa
« Reply #11 on: March 02, 2017, 02:23:22 pm »
Yeah i dont need it really.
So you suggest buying J-Stik Ball-Top or similar? I prefer the ball top ones.
Or are there even better options here: http://www.ultimarc.com/store/section.php?xSec=6
« Reply #12 on: March 02, 2017, 02:28:14 pm »
Since buttons are inexpensive, you may also want to consider:
- P1/P2 Start buttons
- Some other pushbuttons to compare to the Goldleafs
The other question is which size QDs will you get for the Mini-PAC harness?
Goldleaf buttons have 2.8mm (0.110") tabs.
The other buttons have 4.8mm (0.187") tabs.
You may want to hold off on ordering the Mini-Pac until you decide which buttons you want to use.
If you want some buttons with 2.8mm tabs and others with 4.8mm tabs, you can either:
1. Order the harness with 4.8mm QDs.  Try to avoid wiggling the 2.8mm tabs loose and/or use pliers to gently pinch the contacts tighter.
2. Make adapter wires with a male QD on one end (connects to harness) and a female QD on the other. (connects to the microswitch tab)
Raitsa
« Reply #13 on: March 02, 2017, 02:55:46 pm »
Big thanks for the help here guys, now the cart looks like this:
Goldleafs have 2.8mm connector tags so for the Mini-PAC I chose the right one which is for 4.8-2.8mm connectors.
Looking good now for MAME only?
Well, the 2 extra buttons are for there for perhaps for some future pinball use.
« Reply #14 on: March 02, 2017, 03:33:35 pm »
2 Goldleafs for pinball flippers.
P1 and P2 each get a joystick, 6 Goldleafs for player buttons, and a Start button.
That's everything you have in your cart now.
Are you planning on using "shifted functions" for admin functions like P1 Coin, P2 Coin, Exit, Pause, etc. or would you prefer dedicated admin buttons?
https://web.archive.org/web/20160809113045/http://newwiki.arcadecontrols.com/index.php?title=FAQ#Number_of_admin_buttons
Number of admin buttons
Commonly used admin buttons/function include P1/P2 Start (1/2), P1/P2 Coin (5/6), Pause (P) and Exit. (ESC)
To keep guests or children from accidently messing up their cab configuration, many individuals choose to not include a Menu (Tab) button and disable the shifted function for Menu. (P1 Start + joystick right on I-Pac)
There are several schools of thought concerning admin buttons -- some people prefer dedicated admin buttons, while others prefer using "shifted functions".
Dedicated admin buttons:
    PRO + Button functions can be clearly labeled on the panel art or using inserts in translucent buttons.
    CON - Too many buttons can be confusing and make a panel look cluttered.
Commonly used dedicated admin buttons include P1/P2 Start, P1/P2 Coin, ESC (exit), Pause, and others. Some console emulators may also require additional functions so be sure to install and configure desired emulators before building your panel.
"Shifted functions":
    PRO + Can make the panel look less cluttered.
    CON - When the "shift" button is pressed, any button pressed at the same time will output the associated shifted function. This may trigger an unintended function (exit, pause, menu, etc.) during a multi-player co-op game when one player performs a shifted function and the other player continues playing.
"Shifted functions" require a button/input to act as the "shift" button -- P1 Start on the IPac, HWB on the KADE, and Shazaaam! on the KeyWiz.
Pressing P1 Start and P2 Start will cause an IPac to output ESC. (exit)
Include an instruction card on the control panel overlay or screen bezel so family members and guests can figure out how to operate the cab.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #15 on: March 02, 2017, 06:52:45 pm »
Wow, you just wanna throw money at this thing eh?
That computer spec is completely overkill.
If you like overkill, you're doing great so far!
« Reply #16 on: March 02, 2017, 07:45:59 pm »
Ugh. Don't recommend those last two types of buttons.
Raitsa
« Reply #17 on: March 03, 2017, 04:30:56 am »
Thanks again PL1, I think I am gonna go with the shifted functions, looks like thats what i've been using with the old setup and had no problems with that.
Raitsa
« Reply #18 on: March 03, 2017, 01:46:18 pm »
Changed the joysticks.
Andy´s marketing words made me do it.
Shall i press the order button now?    ::)
thewisteron
  • Last login:May 03, 2020, 08:04:40 pm
« Reply #19 on: March 03, 2017, 02:18:17 pm »
I see you went back to the U360s  :laugh:
If it makes you feel better, I bought 4 of them for my 4player panel. I don't regret it.
Combining those with your PC specs, are you sure you're only going to be playing old school MAME on this thing?  ???
Raitsa
« Reply #20 on: March 03, 2017, 02:23:05 pm »
Yeah back to the U360s, they just seem so... cool you know.
I wanna make this a good one, for me & my son to enjoy for many years.
For now only MAME but probably pinball, C64 and other stuff as well in the future.
Havent really familiarized myself with the other more modern & powerful stuff yet.
« Reply #21 on: March 03, 2017, 02:24:16 pm »
The other thing that you mentioned earlier is a U-Trak trackball.   :dunno
Raitsa
« Reply #22 on: March 03, 2017, 02:37:22 pm »
Yeah sorry about the trackball:
to be frank, i dont think i have ever used a trackball outside of an arcade so thats where i am gonna save some money now.
I dont really feel I miss any of the trackball games...
I could always add it afterwards if i feel like i need to add it.
« Last Edit: March 03, 2017, 02:40:06 pm by Raitsa »
Raitsa
« Reply #23 on: March 03, 2017, 04:09:43 pm »
I put in the order above, thanks a lot for all of you who helped me out.
ugleymatt
  • Last login:October 11, 2022, 12:13:37 pm
« Reply #24 on: March 03, 2017, 06:54:59 pm »
Do you need the miniPAC? I thought the 360 sticks would allow you to wire the buttons into them and then they connect via usb?
Raitsa
« Reply #25 on: March 04, 2017, 05:00:08 am »
Not sure myself.
Hopefully i did not order an unnecessary part.
Raitsa
« Reply #26 on: March 08, 2017, 01:25:42 pm »
Stuff ordered from Ultimarc (UK) on Saturday, received on Wednesday (Finland), fast service, thanks Andy  :cheers:
