Author Topic: Sega daytona 4 way shifter wiring into mame driving cabinet.  (Read 3444 times)
Ward-iz
  • Last login:March 28, 2018, 05:26:55 am
« on: February 25, 2017, 09:22:40 am »
Hi there im trying to wire up a daytona 4 gear shifter into my driving cab . The shifter has 3 micro switches and ive wired them into my u-hid board . Ive tried for hours to get all 4 gears working but it only swaps between 1st and 2nd gear , or 3rd and 4th . Not all 4 gears working at the same time . Ive been trying to configure it for the model 2 emulator so i can play daytona properly .
Any help would be much appreciated.
thanks.
SailorSat
  • Last login:Yesterday at 10:18:23 pm
    • For Amusement Only e.V.
Re: Sega daytona 4 way shifter wiring into mame driving cabinet.
« Reply #1 on: February 25, 2017, 06:21:14 pm »
You will need to use a 3-to-8 decoder IC or some micro controller.
« Reply #2 on: February 25, 2017, 06:24:36 pm »
http://forum.arcadecontrols.com/index.php/topic,106709.msg1130578.html#msg1130578
There are several solutions in that thread, but scroll to bottom for the best solutions.
(either adding a switch or using a demultiplexer)
Ward-iz
« Reply #3 on: February 27, 2017, 12:49:39 am »
Thanks for the help, I installed a micro switch for each gear and it works perfectly.
