Author Topic: Wire  (Read 1847 times)
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
Wire
« on: January 24, 2004, 11:43:02 pm »
What is the wire called that you can slide onto the microswitches? Its wire and it has a metal part on the end that slides on... You find them connected to speakers too.
Thanks,
-Nightmare
Chris
    • Chris's MAME Cabinet
Re:Wire
« Reply #1 on: January 25, 2004, 12:13:39 am »
The connector at the end of the wire is a .187 female quick disconnect.  Home Depot will have the .250's, but to get the .187's you'll probably have to go to Ace Hardware or TruValue, or order them online.  You'll need the ones for 18-22 ga. wire; these are usually color-coded red.  If you're ordering parts from Happs, you can find them at http://www.happcontrols.com/wp/item_search.html?item-no=43-0538-00.
You'll also need a crimping tool to crimp them onto the wire, and the wire should be stranded hookup wire, not solid.
(Link fixed by moderator)
« Last Edit: January 25, 2004, 06:48:25 am by JustMichael »
--Chris
Nightmare03
  • Stupid llama!
Re:Wire
« Reply #2 on: January 25, 2004, 12:31:02 am »
Thanks dude,
-Nightmare
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re:Wire
« Reply #3 on: January 25, 2004, 10:06:09 am »
I've got both Red and Blue .187s available.  See the thread in the 'For Sale' forum.
