Author Topic: How to shut down computer and use vol up/down with ipac2?  (Read 2149 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: February 19, 2017, 03:59:42 am »
I see the website talks about it but no one shows how to do it :(
Titchgamer
« Reply #1 on: February 19, 2017, 04:10:34 am »
Do you want to control system volume or MAME volume?
Mame volume is easy as you can set a shifted key for vol up & down then set those keys in the mame control set up.
The default for mame is the + & - keys.
System volume is a bit hardsr and depends on Windows version but you need to keyboard shortcuts and again set shift keys for most.
As for the power I assume you have already extended your pc power switch to your cabs exterior? If so just go to ure power management options and set it to shutdown pc on button press simples :)
equlizer
Re: How to shut down computer and use vol up/down with ipac2?
« Reply #2 on: February 19, 2017, 02:44:23 pm »
I want control of system volume and to power on the arcade with the ipac.  Their website says it can but doesn't explain how :(
baritonomarchetto
  • Last login:Today at 10:51:03 am
« Reply #3 on: February 19, 2017, 04:12:00 pm »
The system volume control is wery OS specific, so i would exclude that interface can do anything on this regard.
A different point would be control MAME volume...
