Author Topic: QBert Mame 182 sounds drugged  (Read 9743 times)
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« on: February 15, 2017, 05:39:46 am »
Something weird happened when I updated my Mame install. I was on Mame 169, qbert sounded great. Mame 182, the sound is crackling, and the initial "Hello I am turned on" at start sounds very slow and drugged. I updated the sample file and still the same. Did Qbert break in the new Mame? Is there a way around it?
haynor666
  • retro maniac
Re: QBert Mame 182 sounds drugged
« Reply #1 on: February 15, 2017, 02:12:02 pm »
Because mamedev added discrete sound emulation and Votrax chip. Game rely now on emulation not on external samples (except one sample).
MydknyteStyrm
  • Makeup FX Gamer
« Reply #2 on: February 15, 2017, 02:24:46 pm »
I deleted the qbert.zip sample and still have the same sound issues.
B2K24
  • Last login:June 10, 2025, 10:17:56 am
« Reply #3 on: February 15, 2017, 02:41:41 pm »
There's nothing you can do. It's still a W.I.P.
http://mametesters.org/view.php?id=6462
« Reply #4 on: February 15, 2017, 04:20:20 pm »
Heh.  Well that only took 20 years. ;)  Good job to them.
MydknyteStyrm
  • Makeup FX Gamer
« Reply #5 on: February 15, 2017, 07:45:15 pm »
Thanks for the tip. I'll have to use 169 on my arcade till they fix it. Don't fix what ain't broken :)
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: February 16, 2017, 05:36:41 am »
... is not a philosophy that programmers follow  ;D
MydknyteStyrm
  • Makeup FX Gamer
« Reply #7 on: February 16, 2017, 06:29:32 am »
Very true.
« Reply #8 on: February 17, 2017, 05:57:14 pm »
Technically it was broken though and now it is closer to being fixed, so that philosophy doesn't really apply.
billfor
  • Last login:October 01, 2025, 12:07:26 pm
« Reply #9 on: September 04, 2017, 12:12:45 pm »
I was doing some work trying to upgrade my Groovymame and noticed the same issue. I made a patch to revert it back to the old samples so I can play it while they are still working on the new votrax code. You will need the old samples. I have only tried this with plain mame and groovymame v186 but it probably works with the current version at this time (v189).
https://drive.google.com/open?id=0B7HaN49URy_BVjc1YnlfMVZuVDQ
MydknyteStyrm
  • Makeup FX Gamer
« Reply #10 on: October 29, 2018, 09:50:15 am »
Thanks for the reply. I saw your votrax code, but dont know how to implement it. Do I make a qbert.ini, or a votrax.ini, or what? Thanks for any help you can provide.
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« Reply #11 on: October 29, 2018, 01:43:49 pm »
What he provided is a patch that you can use to compile your own MAME executable build.
The MAME team has instructions on how to do that here.
"The Manuel"
