Author Topic: .  (Read 32949 times)
ChanceKJ
« on: February 11, 2017, 04:30:00 pm »
« Last Edit: March 19, 2021, 12:25:50 am by ChanceKJ »
n3wt0n
Re: TCA - Ghouls n' Ghosts Project cab pickup and Restoration!
« Reply #1 on: February 11, 2017, 07:17:46 pm »
That doesn't look too bad. I like the screw through the t-molding. Awesome game, good luck with the restore.
« Reply #2 on: February 11, 2017, 07:34:13 pm »
thanks for the pix.
That is a gnarly chunk out of the front. Bondo fill or cut and replace the wood?
  • Last login:Today at 06:31:37 pm
« Reply #3 on: February 11, 2017, 07:57:02 pm »
I like those control panels where you just need to replace that little plate. Since I have access to a plasma cutter, I'd be making myself panels left and right if I had one of those.
ChanceKJ
« Reply #4 on: February 13, 2017, 12:29:15 am »
« Last Edit: March 19, 2021, 12:25:55 am by ChanceKJ »
JoshODBrown
  • Last login:November 09, 2020, 07:05:52 pm
  • It's better to get pissed off than pissed on.
    • The Canadian Arcade
« Reply #5 on: February 14, 2017, 12:57:46 am »
For that corner, or any corner where its not quite a large enough bit of damage to warrant just cutting out the corner and adding in a new piece of wood.. I've had good results adding in either a bit of wooden doweling rods, or some screws to act as a sort of as rebar for when i formed bondo around it, just to give it a little bit of strength/durability. If you try to rebuild the corner from just bondo alone , at some point in the future if it happens to gets a bit of force on that corner (getting kicked or banged around), it might just snap out the chunk of bondo. I used screws on my Joust corner touchup a few years back, wish I took pictures of it, but its held up great, and you'd never know it was repaired that way.
« Reply #6 on: February 14, 2017, 07:44:21 am »
I use dowels too, for this cab I'd get some corner guards to go over the repair work
« Reply #7 on: February 14, 2017, 09:22:05 am »
If the corner is supposed to be square I've had good luck patching in plywood.  It holds better than bondo for the corners.
http://forum.arcadecontrols.com/index.php/topic,103771.msg1536604.html#msg1536604
ChanceKJ
« Reply #8 on: February 22, 2017, 03:23:16 pm »
« Last Edit: March 19, 2021, 12:26:01 am by ChanceKJ »
jdbailey1206
« Reply #9 on: March 29, 2017, 06:00:49 am »
WHY DO ALL YOUR BEGINNING POSTS HAVE SUCH A LARGE FONT?  ITS NOT LIKE ANYONE IS GOING TO OVERSHADOW IT...
ChanceKJ
« Reply #10 on: March 29, 2017, 02:07:28 pm »
« Last Edit: March 19, 2021, 12:26:12 am by ChanceKJ »
jdbailey1206
« Reply #11 on: March 29, 2017, 02:16:49 pm »
haha, :)
because the default text looks so small compared to the pictures.  stretches a full paragraph out to one line. looks silly.
Whajja say?  Type louder!
ChanceKJ
« Reply #12 on: April 06, 2017, 05:17:00 am »
« Last Edit: March 19, 2021, 12:26:18 am by ChanceKJ »
  • Last login:February 02, 2026, 07:47:27 pm
« Reply #13 on: April 06, 2017, 09:54:17 am »
Restoring coin doors takes "a ton of time?"  90 seconds of shaking the rattle can of hammered black, bro.
ChanceKJ
« Reply #14 on: April 06, 2017, 02:29:09 pm »
« Last Edit: March 19, 2021, 12:26:23 am by ChanceKJ »
« Reply #15 on: April 06, 2017, 02:40:21 pm »
True, those videos don't make themselves.
ChanceKJ
« Reply #16 on: April 06, 2017, 03:58:34 pm »
« Last Edit: March 19, 2021, 12:26:28 am by ChanceKJ »
morton
« Reply #17 on: April 15, 2017, 10:34:55 am »
 :banghead:
This ones pretty grimy. It would need to be stripped completely, parts all cleaned, tarnish removed, and the holes patched. Id rather just skip that for this one and get started on more important stuff.
I will attest to this. It's the difference in time between a new coat of paint on the outside vs. essentially making a whole unit from parts... Because if you're gonna do it right, do it the whole way. Especially when its mechanical parts... Nothing like something that looks nice but doesn't work anywhere near as nice.
Looking good Chance. I dig the corner trick... Have you ever considered grafting on a section of cab? This one doesn't seem bad, but have seen some who have added a chunk of wood to replace missing pieces. Looks tedious either way.
ChanceKJ
« Reply #18 on: April 15, 2017, 04:26:23 pm »
« Last Edit: March 19, 2021, 12:26:32 am by ChanceKJ »
Locke141
  • Never grow up.
« Reply #19 on: April 16, 2017, 10:35:11 pm »
Looks good.
I've nothing but for frustrated members of G&G at Pizza hut.
Good luck.
« Reply #20 on: April 25, 2017, 12:15:37 am »
If you're going this far on the cab, you might as well re-finish the original doors.  The HAPP won't look right.  It's equivalent to someone doing an awesome job on a cabinet and then slapping an X-Arcade on there because it's "easier".
DeL
64bitmatthew
  • Last login:July 19, 2017, 12:11:04 pm
« Reply #21 on: May 03, 2017, 12:07:02 pm »
Any updates on this cab Chance? I figure you are probably busy with your two new cocktail cabinet projects, but I'm excited to see how this one turns out.  I love Ghouls n' Ghosts, but have only ever played the home console versions of the game
ChanceKJ
« Reply #22 on: May 03, 2017, 04:21:26 pm »
« Last Edit: March 19, 2021, 12:26:58 am by ChanceKJ »
morton
« Reply #23 on: May 12, 2017, 09:16:13 am »
(won't be purple... don't worry).
ChanceKJ
« Reply #24 on: June 08, 2017, 02:33:30 pm »
« Last Edit: March 19, 2021, 12:27:04 am by ChanceKJ »
ChanceKJ
« Reply #25 on: June 10, 2017, 04:36:59 am »
« Last Edit: March 19, 2021, 12:27:08 am by ChanceKJ »
  • Last login:February 03, 2026, 02:03:18 pm
« Reply #26 on: June 12, 2017, 06:33:06 am »
Do yourself a favor. Don't front load a bunch of reasons why people are not going to like your choices. Just put it out there and let the choices speak for themselves. It betrays a lack of confidence in those decisions.
Also. Does the internet really need another laminating video? There are thousands of them already.
« Last Edit: June 12, 2017, 06:36:59 am by Mike A »
« Reply #27 on: June 12, 2017, 11:23:51 am »
This one's just for Canadians only. Did you see the title?
« Reply #28 on: June 12, 2017, 11:30:43 am »
When did Canada become a country? :dunno
ChanceKJ
« Reply #29 on: June 12, 2017, 04:13:55 pm »
« Last Edit: March 19, 2021, 12:27:14 am by ChanceKJ »
« Reply #30 on: June 12, 2017, 04:17:27 pm »
We were going to remodel anyways. We had to let you do something to boost your self esteem. :cheers:
Thank you for John Candy. You can take Bieber back any time now.
ChanceKJ
« Reply #31 on: June 12, 2017, 04:22:21 pm »
« Last Edit: March 19, 2021, 12:27:19 am by ChanceKJ »
« Reply #32 on: June 12, 2017, 04:31:38 pm »
At least take Howie Mandel back.
thomas_surles
« Reply #33 on: June 12, 2017, 04:36:59 pm »
I always assume Canada is like one big episode of the trailer park boys.
ChanceKJ
« Reply #34 on: June 12, 2017, 05:10:26 pm »
« Last Edit: March 19, 2021, 12:27:24 am by ChanceKJ »
« Reply #35 on: June 12, 2017, 05:13:30 pm »
I can live with that.
ChanceKJ
« Reply #36 on: June 12, 2017, 05:19:33 pm »
« Last Edit: March 19, 2021, 12:27:28 am by ChanceKJ »
« Reply #37 on: June 12, 2017, 05:20:51 pm »
I will even make it the Captain America Cheez Its.
« Reply #38 on: June 12, 2017, 10:20:36 pm »
I am interested to see this finished, because I love white sided arcade cabinets and laminate.
Did you sell Lighting Fighters yet?
ChanceKJ
« Reply #39 on: June 13, 2017, 03:27:40 am »
« Last Edit: March 19, 2021, 12:27:33 am by ChanceKJ »
