Author Topic: Bolt/screw question  (Read 1994 times)
Yander
  • Last login:July 08, 2013, 08:00:14 pm
Bolt/screw question
« on: January 24, 2004, 06:24:01 pm »
What do ypu guys use to hold down plexi glass or lexan to the top of your control panel?
Also does crystalite work as well as lexan?
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re:Bolt/screw question
« Reply #1 on: January 24, 2004, 07:11:29 pm »
None of the above.  I depend on my pushbuttons and trackball mounting place to hold it down.  It holds it down perfectly and you can not lift it if you tried.  However, I have a large 4 player control panel with buttons near some of the edges.
Yander
« Reply #2 on: January 25, 2004, 10:26:54 am »
That never occured to me. I might try that even though I only have a 2 player CP.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #3 on: January 25, 2004, 02:40:21 pm »
I used these, one on each corner
I think they look pretty good, almost just liek rivets on a CP
The ones n the middle of the page, not the first pcitures
TalkingOctopus
    • My Arcade
« Reply #4 on: January 25, 2004, 04:39:13 pm »
If you do try it, a push button wrench may be helpful to get the buttons fastened really well.  Here is an example of one:
http://www.happcontrols.com/pushbuttons/53800300.htm
