Author Topic: MTG-2902SN vision pro Svga  (Read 2053 times)
muell67
  • Last login:May 23, 2021, 02:12:01 pm
« on: February 08, 2017, 09:55:34 pm »
I just got this monitor it was nos. I can't seem to get it to display from my pc. It's windows 7 I switched the resolution to 800x600 at 60khz then unplug from my LCD then into the monitor. It flashes out of range then shuts down. I can't figure out the problem the monitor should be capable of this resolution. I have no idea what I'm doing wrong. Anyone have any ideas?
I don't know if you know this but I'm sort of a big deal. I own many leather bound books and my apartment smells of rich mahogany.
mourix
  • Last login:March 01, 2026, 04:11:03 pm
Re: MTG-2902SN vision pro Svga
« Reply #1 on: February 10, 2017, 05:31:04 pm »
It might be a start to confirm your pc actually keeps the right resolution when you plug in the vision pro. Plug in the LCD and CRT at the same time, and then try to change the resolutions using the LCD.
muell67
« Reply #2 on: February 11, 2017, 09:29:40 pm »
I tried that and set it to 800x600 at 60hz and it still said out of range. I just bought a HD 5450 for another machine so Im going to try that card with crt emudriver instead of the nvidia and see if that makes any difference. I did try the monitor with a 60-in-1 set on 31khz and it displayed fine so I know the monitor is at least working.
