Author Topic: RB pie with Kade inside arcade stick?  (Read 5678 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: February 07, 2017, 07:17:59 pm »
I have a custom made arcade stick i made a few years back with a Kade inside of it.  I'm now wanting to put a raspberry pie inside of it with emulation station.  What is the best way around this?  Can i plug the kade into the pie?  Do i have to program the kade to something the RBpie can see?  Thx
« Last Edit: February 07, 2017, 07:33:02 pm by equlizer »
jeremymtc
  • Last login:February 14, 2026, 05:36:37 am
Re: RB pie with Kade inside arcade stick?
« Reply #1 on: February 07, 2017, 09:10:15 pm »
equlizer
« Reply #2 on: February 07, 2017, 11:56:16 pm »
Move thread pls :)
  • Last login:Today at 05:04:51 am
« Reply #3 on: February 08, 2017, 01:31:09 pm »
I haven't tested with a RasPi, but it should work fine because IIRC Jon wrote the KADE keyboard and joystick firmwares to be USB/HID compliant.
Slippyblade
« Reply #4 on: February 08, 2017, 08:32:09 pm »
The Pi sees the Kade as a keyboard.  Nothing more or less, so no issues at all.
equlizer
« Reply #5 on: February 08, 2017, 09:18:45 pm »
So ill need 3 wires coming out of the arcade stick.  Power for the Pi, usb and hdmi correct?
« Reply #6 on: February 08, 2017, 10:13:31 pm »
What's the purpose of an external USB cable?
You should be able to fit the RasPi and KADE inside the stick enclosure.
That leaves two external connections: power and HDMI.
equlizer
« Reply #7 on: May 24, 2017, 11:05:48 pm »
Sorry to bring it up again :)  I want to be able to keep it as just a stick too if possible for 2 player SSF5 at friends house.  Is it possible to switch between those 2 modes?
thomas_surles
« Reply #8 on: May 24, 2017, 11:41:05 pm »
Here is my idea for that.
1st get a usb splitter
Connect the kade to this (its usb out right?) In the female end. Plug one of the male ends into the pi. Then get a usb extension  and plug the female end into the other male end of the splitter for your usb out. Idk it might work
« Reply #9 on: May 25, 2017, 12:18:34 am »
Nothing to be sorry about, you're just exploring options.   ;D
I think it's possible, but it might get a little cramped inside the case if thomas_surles' splitter idea doesn't work (Will applying power from other computer's USB to the RasPi USB port through the splitter cause a problem with the RasPi?  :dunno ) and you have to go with a switch like this, this, or this.
It sounds like you're looking for a setup like this:
---------------------------------- Contained inside the case -|-Could be either-|-External connections
        _______________ Power supply __ Electrical outlet    (Barstick mode)
Controls __ KADE __ USB Switch __ RasPi __HDMI feedthru ______________ HDMI cable to TV  (Barstick mode)
                                          \_______ Neutrik USB feedthru ______________ USB to computer  (Fightstick mode)
If you use a gamepad firmware, you shouldn't have any problems
If you use a keyboard firmware, you may want to install a "shift lock" button/rocker switch to change between P1 keys and P2 keys or you can set up your RasPi to use P2 keystrokes for P1 functions.
EDIT: Removed link to switch that wouldn't work for this.
« Last Edit: May 25, 2017, 12:25:25 am by PL1 »
