Author Topic: epsxe graphics plugin  (Read 1694 times)
eddweed
  • Last login:April 01, 2004, 11:50:44 am
« on: January 24, 2004, 12:06:51 pm »
Hi I've epsxe running in my cab on an arcade monitor with arcadevga. Just wondering what the best gpu plugin to use is. Thanks for your help
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:epsxe graphics plugin
« Reply #1 on: January 24, 2004, 01:26:50 pm »
Pete's are the best. Current version is 1.75. The Arcade VGA is basically a Radeon so his D3D plug will probably do you best. If you dont have 1.75 they are here:
http://home.t-online.de/home/PeteBernert/#Pete's%20Windows%20GPUs
All Your Base Are Belong To Us!
  • Last login:January 17, 2026, 03:40:02 pm
« Reply #2 on: January 26, 2004, 10:59:29 am »
That's a common misconception..... ati cards have great d3d support, but they create a richer, more detailed, render if you use opengl.
Spaced Invader
« Reply #3 on: January 28, 2004, 08:58:40 pm »
No misconception...my bad, I should have been more clear. I was speaking specifically about the combination of this plugin and a Radeon (more specifically MY 7500...from my own experience, of course). I've simply found the D3D plugin to be more stable with fewer graphic glitches and higher compatibility. Again, my experience...
But you are right about the "common misconception" thing. I've heard that before, and it may have been true for early drivers, but I've never found that to be the case and all things being equal I always choose Opengl.
Once again, I have to recommend Pete's D3D. Your mileage may vary.
