Author Topic: Slot Cutter Size  (Read 3840 times)
thedarkknight228
  • Last login:March 17, 2017, 05:55:22 am
Slot Cutter Size
« on: February 01, 2017, 04:57:13 am »
If my side panels are 12mm thick.
Is it feasable to cut a slot in it for T-Moulding?
Or will it be too weak then?
The image of the T-Moulding I think I need is below.
I presume I need a half inch T-Moulding.
It says 1/16 slot needs to be cut.
So do I need to get a 1.5mm slot cutter bit for my router?
Whatthewhat?
  • Last login:January 16, 2019, 02:56:39 pm
Re: Slot Cutter Size
« Reply #1 on: February 02, 2017, 05:47:23 pm »
12 mm (1/2) is pretty thin for side panels.  Is this for a full-size cabinet or a bar topper?
thedarkknight228
« Reply #2 on: February 03, 2017, 04:06:09 am »
It is for a bartop cabinet
« Reply #3 on: February 03, 2017, 07:06:50 am »
I cut slots in my bartops, 1/2" material.  I would recommend finding a 1/16" slot cutter, as 1.5mm is a little too small and the barb may cause your material to crack.
« Last Edit: February 03, 2017, 07:34:58 am by HaRuMaN »
thedarkknight228
« Reply #4 on: February 03, 2017, 07:28:05 am »
I cut slots in my bartops, 1/2" material.  I would recommend finding a 1/16" slot cutter, as 0.5mm is a little too small and the barb may cause your material to crack.
Yeah a 1/16" slot cutter is what I was thinking of using
