Author Topic: wireing an optical joystick......  (Read 1333 times)
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« on: January 24, 2004, 04:20:01 am »
I have never installed an optical myself and am a little in the dark about what people do to get the 5v line inside of their control panel.
Are there any special parts you need to do this , if so what will i need?
Any help would be great.
groovY~ :D
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:wireing an optical joystick......
« Reply #1 on: January 24, 2004, 05:27:34 am »
You need a multi meter.You will be wiring it for what ?
If i-pac then you can ask someone here who installed one already,they should know where the 5+ is on ipac PCB.
(PM oscar)
5+ is the red wire on most playstation pads and the blue wire is 5+ on official dreamcast pad.
~ :D
« Last Edit: January 24, 2004, 05:28:32 am by SNAAAKE »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: January 24, 2004, 05:49:12 am »
You can get 5v from alot of places.
If you have an IPAC there is a 5v pin on it, read the ipac FAQ/Instructions.
You can get it form a usb port.
You can get it from an harddrive power plug.
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« Reply #3 on: January 25, 2004, 11:37:26 am »
You can also get +5 volts / ground from an Opti-Pac.
Here'a photo from my setup. I didn't need the player 2 spinner or trackball terminals for controls.
« Last Edit: January 25, 2004, 11:39:22 am by Oldskool »
%$#@!&* machine took my quarter!
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
Re: wireing an optical joystick......
« Reply #4 on: December 23, 2004, 11:55:28 pm »
Does only the USB optipac provide power, or does the serial one, too?
