Author Topic: Issues updating GroovyArcade/GroovyMAME Linux  (Read 3276 times)
Moburma
  • Last login:April 05, 2018, 05:28:42 pm
« on: January 29, 2017, 03:28:33 pm »
Hi all,
I've seen a few topics on problems related with updating Groovyarcade, but I've not seen discussion of this particular issue. Specifically, if I run pacman -Syyu (or even just -Syu), everything updates fine, but I then lose 15khz mode on boot up. I might be missing something here, but I tried the fix video scripts but they don't seem to work. The end result is I have a system that only outputs in 15lhz when I run MAME itself. Any ideas what I'm missing?
Second issue is that if I update Groovymame itself, my Xbox pad stops working. Everything works fine with the version included with the original install version (0.177), but if I use any of the newer versions posted it simply isn't detected by MAME anymore. I wonder if anyone knows if this is some kind of OS/SDL driver issue? This is one of the reasons why I wanted to run the OS update above, but if I do that I get the non 15khz on boot issue. Sorry if I've missed the answer to any of this elsewhere!
Also any chance of a new liveCD? The new PortAudio feature seems a good place to bring things up to date!
intealls
  • Last login:January 16, 2026, 05:54:53 pm
Re: Issues updating GroovyArcade/GroovyMAME Linux
« Reply #1 on: January 29, 2017, 06:46:28 pm »
PortAudio mostly makes a difference on Windows. On Linux, latency is already quite low.
badgerme
  • Last login:October 27, 2018, 09:28:05 am
« Reply #2 on: October 27, 2018, 08:53:11 am »
Hi there - did you ever find a fix for this? I also have the same issue where it boots in to 31khz until you open GroovyMame and then it opens in 15khz as it should...
Many thanks!
Doozer
  • Z80 ERROR
« Reply #3 on: October 28, 2018, 02:29:05 am »
Many thanks!
Hi badgerme,
In order to preserve your kernel and not have it updated, you should add it to the list of package that you do not want to have upgraded.
This must be done before issuing the Pacman command.
sudo vi /etc/pacman.conf
Then add the following line
IgnorePkg = linux
