Author Topic: Wells Gardner K7400 25" Monitor  (Read 3088 times)
Kyle Davis
« on: May 15, 2002, 10:33:33 am »
I'm planning to build a cocktail table of my own design, and I'm considering using a Wells Gardner K7400 because it's available directly from Wells Gardner for $360, which isn't bad for a brand new 25" arcade monitor.
http://www.wellsgardner.com/wellsgardner31/finditem.cfm?itemid=690
On their site, it says that it does not come with a power cord.  Does anyone know if it just uses a standard AC power cord like you see on a typical PC and many other home electronics?
Also, has anyone successfully used one of these monitors in their own project?  If so, I'd like to hear about your experiences/pitfalls with this monitor.
Thanks,
Kyle
StephenH
Re: Wells Gardner K7400 25" Monitor
« Reply #1 on: June 08, 2002, 11:18:37 pm »
You may have better luck with a U3100 or D9200.    This monitor is CGA-Res (15Khz Arcade), which means it can be tricky to setup.  The U3100 and D9200 support VGA/SVGA modes, and are easier to setup and wire, as well as safer when running Windows.
Ken Layton
  • Guru
  • Technician
Re:Wells Gardner K7400 25" Monitor
« Reply #2 on: October 28, 2003, 10:06:15 am »
No, it does not use a computer power cord. The power cord is a standard commercial coin-op video game cord and Wells-Gardner sells it as an accessory.
