Author Topic: I need to laminate if i use sidearts?  (Read 4500 times)
Jack
  • Last login:March 07, 2025, 06:28:36 pm
  • See You Space Cowboy..
« on: January 19, 2017, 12:46:58 pm »
I need to laminate first or i can just put the sidearts on the multilayer wood? What do you guys suggest? Thanks.
thomas_surles
Re: I need to laminate if i use sidearts?
« Reply #1 on: January 19, 2017, 01:21:31 pm »
As long as it's smoothe enough. Prime and paint it first.
vinegar
  • Last login:August 12, 2017, 09:07:18 pm
  • ID/hardware hacker
« Reply #2 on: January 19, 2017, 05:35:27 pm »
yup, and that's not a suggestion.  do it or the art will curl right off and be ruined.
« Last Edit: January 27, 2017, 11:31:10 pm by vinegar »
menace
« Reply #3 on: February 13, 2017, 08:25:45 am »
Spray on adhesive before you apply and it will be good to go (without priming and painting) I've learned this from first hand experience and not from a forum post somewhere.  I use 3M 77 adhesive (from lowes).
bdn103
  • Last login:September 05, 2023, 09:29:59 pm
    • Classic Arcade Cabinets - FREE arcade cabinet build plans, printable PDFs and CNC plans
« Reply #4 on: February 23, 2017, 08:24:33 am »
The sideart will amplify every imperfection in the wood. You will need to sand, prime, sand, paint....... and repeat until you have a glassy finish.... or you can glue down some laminate since it is already flat and smooth.  I prefer paint, but laminate is quick and easy.
Brian
Free arcade cabinet build plans. CNC drawings, CAD drawings, and printable templates. http://www.classicarcadecabinets.com
