Author Topic: Simple solenoid circuit  (Read 8769 times)
dylaninwv
  • Last login:October 09, 2019, 07:05:47 pm
« on: January 18, 2017, 09:48:00 am »
Hello, was looking for some insight.
Im restoring an old Standard Metal Typer. The solenoid coin circuit was missing, so I am working on reconnecting it. Basically, drop a coin, closes the microswitch, and momentarily charges the solenoid briefly lift the tab to release the bar lock. The parts are:
Power Supply: 12cDC, 1.75amp
Standard coin microswitch
Solenoid: 21-280, with + and - poles.
Adding in a could 1amp fuses to the circuit as well.
Below is the basic circuit that I thought it should be - am I on the right track?
Titchgamer
Re: Simple solenoid circuit
« Reply #1 on: January 18, 2017, 12:03:55 pm »
Looks fine to me but take the fuse out of the -.
Should only be fuses in the + really.
dylaninwv
« Reply #2 on: January 19, 2017, 08:27:14 am »
 Cool, thanks. I only have a two bay fuse block lying around, which is why I was going to fuse both lines.
Should I bother with a diode or not?
Titchgamer
« Reply #3 on: January 19, 2017, 11:45:08 am »
Dont see why you should need a diode really.
dylaninwv
« Reply #4 on: January 19, 2017, 12:18:20 pm »
Thanks Titchgamer.  :) :applaud: :applaud: :applaud: :cheers:
  • Last login:Today at 04:49:10 am
« Reply #5 on: January 19, 2017, 12:40:57 pm »
Some solenoids and relays have a built-in diode (check the datasheet) that acts as a snubber to prevent chatter when the coil's magnetic field collapses.
There's a with/without diode comparison demonstration from 9:15 - 10:00 in this video.
If there's no built-in snubber and you have a problem with chatter, add a diode.
« Last Edit: January 19, 2017, 12:47:08 pm by PL1 »
Titchgamer
« Reply #6 on: January 19, 2017, 01:09:33 pm »
Cheers Scott,
Learn something new every day :)
