Author Topic: It's all about pots - modding wheel for arcade & x360 use  (Read 3420 times)
jkl
  • Last login:March 13, 2020, 10:01:58 am
« on: January 08, 2017, 03:56:42 pm »
Since I started my x360 pad mod I opened my wheel setup.
It was originally a madcatz mc2 Dreamcast racing wheel still working with my dc but I hijacked the pots connections to a jvs type 1also, so it's working either with the home console or the arcade setup.
It works very good.
Strange thing is that looking the pots I noticed they are 10k pots, that's really good for my current x360 pad analog hack... But I wonder why is that working with jvs also since I knew that arcade pots are often 5k.
And since my electronics-fu is very weak I wonder if using 10k pots with a jvs setup designed for 5k ones can damage something...
« Last Edit: January 08, 2017, 04:16:41 pm by jkl »
  • Moderator
Re: It's all about pots
« Reply #1 on: January 08, 2017, 04:06:49 pm »
It works very good.
It won't hurt anything.
The interface must be measuring voltage, not resistance.  A 5k pot and a 10k pot will divide the voltage just the same.  Do in internet search for potentiometer as voltage divider to learn more.
You can't always swap pots.  A lot of the older stuff worked off measuring resistance instead.
jkl
« Reply #2 on: January 08, 2017, 04:16:12 pm »
First of all thanks for your answer BadMouth!
Experimenting to connect my wheel to xbox360 I noticed the following (already read your thread here):
1) I can measure on original x360 stick pots 2,80Kohm, not 10k as I expected
2) If I remove the pots I can't get it working
3) Wiring my 10k pots in parallel with original ones I have triggers combined on Z-axys (I assume this is correct behaviour), but wheel (x-axys) inverted. So I'm thinking that I could add a 6-pin switch on my wheel pot to invert ground and 5v when using x360 and restoring them just like they are connected now for arcade / DC operation. Sounds it right to you?
Thanks,
JKL
PS: I edited thread title to explain a bit better its contents...
