Author Topic: Anyone know if this will work? (Dual video output at same time on 1 video card)  (Read 2474 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
Hey guys, just wondering ....... on my video card for my PC I have an S video connection (which I use for my Arcade Screen which is simply Sony TV), and I also have a VGA port available on the rear of the PC coming from the same video card.
What happens if I connect the VGA to another external source like a projector? Will it show the same output as my Arcade?
Anyone try this?
I would try it myself but I don't have access to my machine for 2 weeks.
  • Last login:January 26, 2026, 07:56:08 pm
it should. most cards can do many outputs at the same time with no problem.
some older ones couldn't do 3 analog. my old ATI with VGA/SVideo/DVI could only do 2... enabling all 3 (and using a DVI to VGA adapter) would cause the voltage to dip and the video to falter. it would have probably worked just fine if I used the DVI digital cable, since all 3 sources where feeding of the analog signal path.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
You should be able to set the displays as mirrored or extended(2 separate output) under display settings of the PC.
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
When using dual out, do NOT use VGA. You'll run into issues every so often where the VGA monitor will not show the correct refresh rate or signal. If all you have on the video card is HDMI/DVI/Display, and want to use the VGA, simply use an HDMI or DVI to VGA adapter. You'll have alot less headache. But to answer your question, yes it will work, though not as well as it could.
lisowskikevin
Thank you everyone!
