Author Topic: Best video hard for crt_emudriver??  (Read 5086 times)
mitsurugi
  • Last login:November 07, 2025, 04:57:10 am
« on: January 06, 2017, 06:13:07 pm »
Hi.
I need to buy a graphic card, because my ati 4850 have problems with some games like taito type x games in interlaced mode running at half speed.
What is the better graphic card compatible? I will use crt_emudriver 2.0 and windows 7 x64
I have read the better cards are hd5xxx, hd6xxx and hd7xxx, so i'm interested in buy something like ati hd6950 or 7970, but i'm not sure with hd7xxx series, because it could have problems if they are released after catalyst modified drivers (2011 i think).
I want emulate demul so I need the better graphic card compatible with the drivers. Could you help me in my choice?
  • Last login:Today at 04:45:28 pm
Re: Best video hard for crt_emudriver??
« Reply #1 on: January 08, 2017, 03:23:33 pm »
I don't recommend to explore the upper limits of the supported range, unless you already have the hardware and want to test.
Check this thread for instance: http://forum.arcadecontrols.com/index.php/topic,152767.0.html
There are some others.
I wouldn't buy yet however. Either buy a cheap 6450 or wait till I release a new Emudriver version.
Taito Type X games are certainly not guarateed to run either way. These are pirated games glued to a launcher that has a poor support for non-standard resolutions.
buttersoft
  • Last login:November 18, 2025, 07:17:10 pm
  • Is running at 15kHz
« Reply #2 on: January 08, 2017, 05:56:34 pm »
Seconded. TTX is *really* finicky. It's impossible to recommend a card for it - try the games on one combination of hardware and a given number of titles will work fine; try them on a second computer and a completely different list of titles runs. The fact they're originally running (encrypted or under a modified instruction set?) on XP probably doesn't help, but I wouldn't recommend switching to XP either, as people say it doesn't help.
That said, I do ok on a 6870 and 6950. I have both patched with Atom15 and they work well overall. They do need far more power and more connectors, and generate far more heat, than something like a 6450. But I wanted to run games like Grid and Dirt as well as emulators, and the CPU's i'm using are old old old.
...wait till I release a new Emudriver version.
Was that a teaser? Anything you'd care to tell us? ;)
mitsurugi
« Reply #3 on: January 08, 2017, 10:21:51 pm »
For Taito type x games i have find a loader and works fine.
Now the main problem is with model 3 emulator... (supermodel).
I think i will wait with my graphic card.
Calamity thanks for your great driver and support.
buttersoft
« Reply #4 on: January 08, 2017, 10:44:43 pm »
And once you change graphics cards, it may not. I hope it works though, but be warned.
« Last Edit: January 09, 2017, 12:29:34 am by buttersoft »
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #5 on: January 09, 2017, 03:32:16 am »
Yes, do tell please :)
I'm looking to buy right now to upgrade my cabinets...
bent98
  • Hyperspin Moderator
« Reply #6 on: January 11, 2017, 03:56:44 pm »
I posted this in another thread but didnt get a response. Can you guys shed some light?
I just build a new PC running win 7 x64 ultimate that I wanted t replace my XP machine that I had hooked up to my Quad sync Billabs CRT. I just picked up a used 7950HD installed 2.0 beta 8 driver and noticed that Hyperspin mp4 videos dont play and are solid green. I saw a thread about it a few years back and the fix was to disable hardware acceleration in firefox browser but that didnt work. I dont have the computer hooked up to CRT yet, its only hooked to a lcd monitor as I am still installing and configuring my emulators. If I uninstalled the driver and leave the default windows driver it does play the mp4 vids. I also tried installing VLC and a codec package.
Anyone else have this issue? Is the 7950 ati card compatible or did I get the wrong card? I see in this thread people are saying to run 6xxx series card. I can pick up a 6970HD sapphire card for a cheap price. Can someone let me know asap as I only have a few days to send back the 7950 to get a refund.
« Reply #7 on: January 11, 2017, 05:40:39 pm »
Hi bent98,
Check this: https://www.monitortests.com/forum/Thread-AMD-ATI-Pixel-Clock-Patcher
On the first post, ToastyX provides some workarounds for the issue. It's a known problem and it's by design (the drivers break video acceleration purpousely when they are patched).
bent98
« Reply #8 on: January 11, 2017, 08:22:50 pm »
I'll try it out tonight. What about the video card model?
Can I use the 7950hd or do i need to go with a 6xxx series?
bent98
« Reply #9 on: January 11, 2017, 09:42:06 pm »
ok so the fix was to disable hardware acceleration in the adobe flash player. I couldn't access it until i found a website that used flash. Once my browser was playing a flash video only then could I right click and disable it.
Now back yo my video card questions.
Product Identifiers
Brand   MSI
Product Line   ATI Radeon
Model   R7970 TF 3GD5/OC BE
MPN   R7970 Twin Frozr 3GD5/OC
« Last Edit: January 14, 2017, 09:07:55 am by bent98 »
« Reply #10 on: January 12, 2017, 08:34:47 am »
Do you have the card already? If so, and the drivers did got installed, it'll probably work.
The drivers cover a wide range of cards with plenty of them which have been successfully tested. I can test just a few, and always as a rule I do my tests on budget cards of each series. If you as users insist on exploring the upper range right where uncertainty begins (exactly what I don't recommend), it's because you're happy with the experimentation task, which is of course benefitial for all us.
Test mode is required for Windows to load the driver. If the watermark annoys you, there's a tool somewhere to remove it. It has zero side effects over the OS behaviour.
bent98
« Reply #11 on: January 12, 2017, 09:11:11 am »
Ok so then I will test. Will these drivers support max amount of mode-line variations? I remember reading in one of the threads certain video cards only supported 10.
« Reply #12 on: January 12, 2017, 09:40:51 am »
All cards (HD 5000+) supported by driver do support the same features.
In the worst case there's a new Emudriver version in the kitchen that will support all cards up to 2016.
pakoman
  • Last login:November 05, 2024, 08:36:26 am
« Reply #13 on: January 12, 2017, 10:51:11 am »
There is a patch somewhere for the 10 custom res limit  ;D
Calamity, did you manage to easily add the modeline generator to latest drivers?
« Last Edit: January 12, 2017, 12:22:12 pm by pakoman »
Sledge
« Reply #14 on: January 12, 2017, 02:57:09 pm »
Good to hear :)
I shall wait to update my cabinets then!
Is this going to be the signed one?
Do you need donations for that yet?
bent98
« Reply #15 on: January 14, 2017, 09:08:47 am »
If you want a giher end card get the :
Product Identifiers
Brand   MSI
It works well in mame.
