Author Topic: Ideas to extent/connect multiple wires from buttons for easy disconnect?  (Read 2013 times)
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
Hard to explain what I mean in the title . . Basically I have some dedicated buttons on the cab (coin door, pinball buttons on the site, admin panel) that I want to always be connected via a mini-pac inside the cab. But I want to be able to dismount the CP, which hypothetically would use the same mini-pac.
Is there a way to wire the buttons from the CP to something that would allow easy disconnect?
Something like this:
But I'd need to crimp/attach the wiring myself. Right now I have a separate old I-pac handling the cab buttons which is kind of a waste.
  • Last login:Today at 12:27:33 pm
Re: Ideas to extent/connect multiple wires from buttons for easy disconnect?
« Reply #1 on: January 03, 2017, 10:53:58 am »
Cat 5 network cable works.
JDFan
« Reply #2 on: January 03, 2017, 11:28:48 am »
Could use a variety of DB9 or DB25 connectors  depending on how many connections you need
They run from about $1 to $6 depending on the number of connections and come in both male and female connectors
  • Last login:Today at 10:47:28 pm
« Reply #3 on: January 03, 2017, 12:12:29 pm »
How about cutting a DB25 extension cable in half?
Add some loop clamps for strain relief and euro-style terminal strips and you're good to go.   ;D
JDFan
« Reply #4 on: January 03, 2017, 12:27:54 pm »
Good idea - just make sure the one you get is like this one (It says in the description : this serial cable uses a straight-through configuration and wires all 25 conductors.  ) - but some sellers sell ones that are not straight-through configs or leave out some wires !!
« Reply #5 on: January 03, 2017, 03:18:37 pm »
or you could go with a real arcade solution like a 15 molex connector.
keilmillerjr
  • Web Developer.
« Reply #6 on: January 03, 2017, 03:59:51 pm »
Yep. That's what I am doing. Molex parts I ordered from mcmelectronics.
