Author Topic: Joystick Shaft Extenders - Sanwa  (Read 1269 times)
Lamaman1971
  • Last login:June 20, 2024, 01:44:56 pm
« on: January 02, 2017, 06:58:09 pm »
Hi Folks, Im using a set of Happ Competitions in my cabinet and Im thinking about swapping them out for Sanwa's - problem is (and was, when I put the thing together) is that its made of 3/4 inch wood- so the shaft needs to clear the hole. Would it be wise to use a Sanwa with a 1.5cm shaft extender or is there a better solution out there?
