Author Topic: Power Monitor On By Plugging It In  (Read 2669 times)
portableanswers
  • Last login:January 09, 2017, 09:36:58 pm
« on: December 31, 2016, 11:41:43 pm »
I am currently away and do not have access to my monitor model/serial number.
I found an old post regarding this issue but the user never replied how he hacked his monitor.
I need the monitor inside my arcade machine to turn on when it receives power (plugged in).
Right now I am using a remote control.
I understand that some monitors have a setting for this but I do not believe mine does.
I am guessing I need to wire the power button in some way.
Thank you in advance.
« Last Edit: December 31, 2016, 11:44:28 pm by portableanswers »
DorkVonWaterfall
  • Last login:June 27, 2025, 09:35:13 am
Re: Power Monitor On By Plugging It In
« Reply #1 on: January 01, 2017, 04:02:51 am »
if scart then 12v to pin 8
portableanswers
« Reply #2 on: January 01, 2017, 09:27:18 pm »
My apologies, could you elaborate please? I'm inexperienced.  :-\
  • Last login:Today at 02:32:05 pm
« Reply #3 on: January 01, 2017, 10:54:30 pm »
SCART is a standard European 21-pin connector for audio-visual equipment.
buttersoft
  • Last login:Yesterday at 05:29:19 pm
  • Is running at 15kHz
« Reply #4 on: January 02, 2017, 07:55:40 pm »
Was that even what he was asking? I thought he meant that when he powers on his monitor, it comes up in standby mode, so he has to use the remote to turn it on. Which problem I have no idea how to fix properly, and would suggest trying a timed relay on a standby switch, if there is one. You could wire it to the remote button, but that pretty much puts the remote out of use for other purposes.
portableanswers
« Reply #5 on: January 09, 2017, 03:25:34 pm »
Thank you both. Buttersoft, you are correct. That is what I was asking. I have to use the remote. I wonder if I could wire the power button to an external button.
  • Last login:Yesterday at 02:08:03 pm
« Reply #6 on: January 09, 2017, 04:03:36 pm »
Try jamming in the power switch with a toothpick.  Sometimes you get lucky and the TV will turn off and on with the plug after you've done that.
portableanswers
« Reply #7 on: January 09, 2017, 09:37:58 pm »
True. I have tested that method on this TV but it did not work. I should have mentioned that in my initial post. Thank you.
obcd
  • Last login:April 03, 2019, 11:44:36 am
« Reply #8 on: January 10, 2017, 12:36:24 pm »
If you could generate the IR code that turns on the system, you could install the ir led close to the tvset and activate it for a couple of seconds at powerup. Maybe you could use the electronics of a universal remote for this. Some are pretty cheap.
