Author Topic: Wg k7500 monitor adjustment  (Read 2828 times)
mclovin
  • Last login:December 15, 2025, 11:59:25 pm
  • GT newbie
« on: December 26, 2016, 07:29:09 pm »
I have a monitor chassis I just capped. Think it's a wgk7500 everything is good and clear, I would just like to make an adjustment as the monitor does not seem plumb for a lack of a better word. The picture needs a slight adjustment counter clockwise. I'm not sure what this adjustment is called, but is it possible to adjust the picture slightly clockwise or counter clockwise? Thanks
grantspain
Re: Wg k7500 monitor adjustment
« Reply #1 on: December 27, 2016, 03:56:35 am »
do you mean the whole picture needs to  be slightly rotated to make it square -you would need to rotate the deflection yoke fractionally
mclovin
  • GT newbie
« Reply #2 on: December 27, 2016, 11:19:17 am »
Yes exactly. I have not done that before, I'll give it a try. Thanks
ed12
« Reply #3 on: December 27, 2016, 11:48:32 am »
and do it very very slow
or get ready to re converge
ed
mclovin
  • GT newbie
« Reply #4 on: December 27, 2016, 09:20:45 pm »
Ok I had a closer look and it is only the bottom part of the screen that is not running true, I also have a bit of a pincushion issue on the one side in order to get it perfect. I'll Attach a pic.
grantspain
« Reply #5 on: December 28, 2016, 05:08:52 am »
do you have the small daughter board attached,it has a pincushion and traspezoid control
  • Last login:Yesterday at 11:05:02 am
« Reply #6 on: December 28, 2016, 11:03:11 am »
+1. I had a similar issue. I called the guy I bought it from and he told me where the trapezoid adjustment was.
Mine is not a WG, otherwise I would post a pic of the location.
mclovin
  • GT newbie
« Reply #7 on: December 28, 2016, 08:01:17 pm »
Yes, tried adjusting the pots and no real change that I could see.
