Author Topic: Taskbar showing up when loading hyperspin and stays. Cannot play games :(  (Read 1517 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Im not too sure what happened but now when i boot up (now using a samsung evo 840 512gb :notworthy:) the taskbar is visible and hyperspin loads in the background.
My setup is over a year old.  I barely use the machine till now since i upgraded to an SSD.
EDIT: Figured it out :)
« Last Edit: December 18, 2016, 08:01:48 pm by equlizer »
05SRT4
  • Check out my Pow Pow
Re: Taskbar showing up when loading hyperspin and stays. Cannot play games :(
« Reply #1 on: December 18, 2016, 08:14:09 pm »
What was the fix? In case someone else has the same issue.
equlizer
« Reply #2 on: December 24, 2016, 03:00:59 pm »
right click taskbar then properties then auto hide the taskbar.  Seems to have worked for me :)
« Reply #3 on: December 24, 2016, 03:46:05 pm »
I had a problem with the front end not having focus when the computer would load up. I reloaded the OS and the issue persisted. I changed front ends from MALA to Hyperspin and now it works fine. Can't say I ever fully got to the bottom of the Mala issue, but I've used Mala many times before and after and never saw that issue again.
