Author Topic: Help with bits for t molding for UK  (Read 6174 times)
liamb2001
  • Last login:March 01, 2017, 07:34:56 am
« on: December 18, 2016, 03:55:52 pm »
I am really struggling to find the correct bits for my router for cutting the edge for the t moulding trim.
Ive heard its often cheaper to buy from the US but i dont have a clue what im supposed to be buying. Im considering buying either 15mm or 18mm mdf.
Would appreciate any help or advice as any links etc ???
liamb2001
Re: Help with bits for t molding for UK
« Reply #1 on: December 19, 2016, 09:37:05 am »
anyone ?
EssexMame
  • Last login:July 22, 2025, 11:52:28 am
  • Mame Weekender
« Reply #2 on: December 19, 2016, 09:51:35 am »
I got my t-molding, and bit, from t-molding.com in the US (shipped to the UK). I don't remember it taking especially long to arrive.
They did a "Whiteside" bit and arbor IIRC. My mdf is 18mm thickness and I'm led to believe that is what I'd need. 18mm is 3/4"
JDFan
« Reply #3 on: December 19, 2016, 10:04:10 am »
What size slot does the vendor you are buying the t-molding from say it needs ??? Not all same size molding uses the same size slot - so before anyone can tell you where to find the cutting blade they would need to know specifically what size blade you need (otherwise it might be too smal or too large for your specific t-molding.)
For example on t-molding.com they have this pic
Which shows the slot size as 3/32" which would be 0.0938" or 2.3813mm - so you would need a corresponding 3/32" slot cutter blade like this one : ( https://www.t-molding.com/whiteside-slot-cutter-6700a.html )
One reason no one has responded is that most US vendors do not have 15 or 18mm molding ( see attached image ) so not sure what size barb those would have ! But normally what ever vendor you buy the molding from will carry the cutter needed for their product so find the product you intend to use and check what size barb it has and then post it here so others might be able to help find the proper size cutting blade or order both the t-molding and slot cutter from the same vendor to ensure it is the correct size for their product.
nyowns
  • Last login:August 01, 2020, 02:49:21 pm
« Reply #4 on: December 19, 2016, 05:11:16 pm »
https://www.amazon.com/gp/product/B0002TUCRA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 , just a 9/16" slotting bit, should work with whatever T molding you use, also might want to get a rubber mallet or atleast wrap a rag around your hammer when tapping in the t-molding (notice i said tap in and not bang)
Good luck
liamb2001
« Reply #5 on: December 19, 2016, 07:30:11 pm »
Thanks for the comments i appreciate the in depth answers itd been doing my head in.
Here is where i plan on getting the t moulding. I already have a rubbber mallet its just the bits i need now.
« Last Edit: December 22, 2016, 08:02:47 pm by liamb2001 »
liamb2001
« Reply #6 on: December 22, 2016, 08:23:35 pm »
ok so ive been looking into it and been told 18mm mdf is going to be the best but converted to inches the closest t moulding i can find is 3/4 t moulding which i plan on buying here - > https://www.arcadeworlduk.com/products/Red-3-Quarter-Inch-T-Molding.html
Can i ask with that, what bits do i need to buy as im still a little confused ?
also may i ask essexmame, what thickness of wood, t moulding and bit did you order exactly ?
would really appreciate some help
thanks
liamb2001
« Reply #7 on: December 22, 2016, 08:54:10 pm »
am i best buying this https://www.amazon.com/gp/product/B0002TUCRA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
for my 18mm mdf with 3/4 t moulding above or is it best to buy ...
Red T-Molding    3/4" Red T-Molding    40    $0.37    $14.80
Whiteside Slotting Cutter Blade    Whiteside Slotting Cutter 1/16" 3-Wing    1    $17.95    $17.95
Whiteside Slotting Cutter Arbor    Whiteside Slotting Cutter Arbor 1/4" Shank    1    $9.95    $9.95
all from tmoulding
itching to buy this now but dont want to get the wrong bits :(
liamb2001
« Reply #8 on: January 03, 2017, 03:56:59 am »
Anyone ??
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #9 on: January 03, 2017, 04:24:31 pm »
Hey Liam.
The one on Amazon is the same as the 2 separate pieces you provided.
As long as it cuts a width of 1/16" and about 1/2" deep you'll be find with the 3/4" t-Molding. 1/16" is tight enough but not tight enough to split the wood.
I don't know if this would be cheaper for you but this is where I bought my router bit:
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
Item ##5341. Pretty much the same as the Amazon bit.
« Last Edit: January 03, 2017, 04:26:23 pm by UEDan »
liamb2001
« Reply #10 on: January 04, 2017, 08:55:48 am »
UEDan thankyou so so much for getting back to me i really appreciate it, ill get hat ordered now.
Many thanks :)
