Author Topic: Power socket c14 with switch wiring  (Read 3118 times)
gomeq
« on: December 13, 2016, 01:23:24 pm »
Hey guys, was searching this forum and the internet for a good wiring diagram for this switch.
Currently the only thing I could find was wiring it this way:
This works but keeps the light in the switch always on. I want the light to be inactive when the switch is turned off and active when turned on.
Can anybody help me with this?
  • Last login:Today at 06:48:16 am
Re: Power socket c14 with switch wiring
« Reply #1 on: December 13, 2016, 01:36:26 pm »
The wiki (backup) has the info and diagrams you are looking for.
https://web.archive.org/web/20150928061832/http://newwiki.arcadecontrols.com/index.php?title=Wiring#IEC_Fused_Power_Inlet_with_a_Lighted_Switch
gomeq
« Reply #2 on: December 13, 2016, 01:52:00 pm »
Okay, thnx!
  • Last login:Yesterday at 03:02:05 pm
« Reply #3 on: December 13, 2016, 02:00:38 pm »
I'd guess the bulb is wired between the tabs on either the left or right side of the switch.
If it stays on all the time, then it must be wired on the power cord side that gets power all the time.
You don't want to use that side for the power inlet then.  You want to use the other side that only has power when the switch is flipped.
So.....
Swap the blue wires on the back of the switch.  Then swap the yellow wires.
(or disconnect the switch, remove it from the housing, flip it over, put it back in, and wire it as pictured.)
If it doesn't work the way you want after that, then the switch just isn't wired in a way to do what you want.
I ripped the bulb out of mine.  :angel:
« Last Edit: December 13, 2016, 02:02:40 pm by BadMouth »
JDFan
« Reply #4 on: December 13, 2016, 04:06:09 pm »
If you wire it with 7 and 8 reversed, the light will be lit all the time.
From the wiki link posted above by PL1
So you need to reverse those 2 wires !
