February 22, 2026, 12:31:29 am
You are probably thinking of the Wico joysticks, which used 3/8" e-clips.A 3/8" e-clip will fit in the groove of the Happ/IL joysticks, but it is a pretty loose & sloppy fit because the groove diameter on the shaft is too small.
