Author Topic: Cave games (320x240 60hz)  (Read 3131 times)
cps2
  • Last login:December 13, 2016, 05:13:18 am
« on: December 08, 2016, 04:53:13 am »
Apologies for starting a new thread, I searched but couldn't find the answer.
I've been running Groovymame for some time on XP and finally made the move to W7. It's amazing and really glad I made the jump. The only games I'm have problems with are the CAVE SH3 vertical shooters. For some reason Switchres insists on choosing 480i rather than 240p I'm using a MS9 with a HD5450 card.
Any help would be appreciated.
  • Last login:Yesterday at 04:02:37 pm
Re: Cave games (320x240 60hz)
« Reply #1 on: December 08, 2016, 12:21:31 pm »
Unless you're using a vertical monitor, I'd say Switchres is doing the right thing.
cps2
« Reply #2 on: December 08, 2016, 12:28:50 pm »
Apologies, I wasn't clear. My MS9 is vertical.
« Last Edit: December 08, 2016, 12:31:23 pm by cps2 »
« Reply #3 on: December 08, 2016, 12:30:28 pm »
Fine. Please post a log to resume troubleshooting.
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #4 on: December 11, 2016, 04:34:20 am »
I use the same graphic card and same monitor, also on windows 7. I have no issue (except maybe the mandatory option to avoid slow down)
cv1k.ini :
triplebuffer 1
I only use this command if I notice slow down in game causing warped records like sounds
vertical.ini :
orientation vertical
So vertical game are forced in vertical orientation.
What's your groovymame version ?
« Last Edit: December 30, 2016, 03:59:34 am by funkycochise »
cps2
« Reply #5 on: December 13, 2016, 05:13:38 am »
I use the same graphic card and same monitor, also on windows 7. I have so issue (except maybe the mandatory option to avoid slow down)
cv1k.ini :
triplebuffer 1
vertical.ini :
Running GM0.180. I fixed the issue by creating a .ini file (similar to your suggestion above) and the vertical resolution is now correct.
funkycochise
  • 8 bits generation
« Reply #6 on: December 14, 2016, 05:05:40 am »
Happy that it works :)
« Reply #7 on: December 14, 2016, 01:27:09 pm »
That shouldn't be necessary.
funkycochise
  • 8 bits generation
« Reply #8 on: December 14, 2016, 03:00:24 pm »
Triplebuffer 1 ?
I'll give 0.180 a try but using 0.171 it is mandatory or else
there are too many drop in emulation %
This happen only with demanding games.
